slantsixdan
For1965 the gas tank was galvanized
Are you quite certain it wasn't terne-plated? I'm pretty sure it was.
Terne plating used to be a low-melt lead/zinc dip, back before seat belts were necessary, back before lead and cigarettes were bad for us. Now it's not necessarily tin/lead but might be tin/zinc. Article here gives the basics but can't necessarily be relied on for precise accuracy; there's no law against lead/zinc terne and it's very likely still in use. There's also Ni-terne, which is when the bare steel is nickel plated before the terne dip -- Ni-terne has long been common in fuel tank manufacture, and while I can't come close to swearing to it, it would be a fairly safe bet that OE tanks were Ni-terned.
As for what it looks like, whether Ni- or not, it doesn't have that granular/crystalline appearance like hot-dip galvanize. Terne is pretty smooth and uniform in appearance; it starts out a semi-dull silvery tone then gradually ages to a darker grey.
As for the J-bolts, I would be surprised if they were bare steel. Probably cadmium plated or chromated, originally.
(Thanks for the props, Leanna! I think that black crud you saw might have been some kinda graphite compound or other process-related gunkum; it doesn't sound like a deliberate coating which would've been more uniform and not streaky.)
A friend of mine stopped bywith a J-hook and you see that it was silver zinc from start!
The window regulator has some kind of grease on. Is that lithium grease?
On the rear drums there should be special clips. In late 1965 they changed! I found the TSC on it!
Makes perfect sense.
Probably. Starts out yellowish-white and gradually turns to yellow-brown.
Interesting, can you post the bulletin?
That TSB is not applicable to your Dart. It pertains to B- and C-body cars only.
Awesome!!!!!
For1965 the gas tank was galvanized but what about the strap and the hook? I'm pretty sure that the strap was galvanized as well as the tank but I have checked out several J-hooks and they seems to be natural with a self locking nut with a red plastic insert.
Does any FABO members have any input to this? They do repop the J-hook with silver zinc finish but that's not assembly line correct!
I just re-did mine (the hook), it was in about the same state as yours if not a tad worse. I put it in a bath of Gelled Rust Remover from Dominion Sure Seal Ltd. Removes rust from chrome eliminates sanding an leaves a protective coating that eliminates further rust and prepares the surface for paint.
I let it soak for 24 hours (fully immersed), and wiped the gel away and then lightly wire brushed by hand and I was blown away by the results which to me was like new. I have used it as is. Actually installed it just last week.
Do you by chance have a picture how it turned out?
Next in line with the body is the find out the right seam sealer and the puddy or what the name is. Then it's time for the greenish primer like Mike Mancini did on the Gold winning 1970 Duster.
http://www.moparaction.com/Article/GROCERY_GOLD/gold.html
AI have going through Internet in search for the right weam sealer. Does anyone have any ideas what Chrysler used back in the day? What is the best brand to use?
Say, that assembly line oil filter is nifty! Old stock or repro?
