1965 MMP's Barracuda Project "Disco Volante"
Members Restorations
  1. jedrattle
    jedrattle Well-Known Member
    327
    91
    Jul 31, 2005
    Riverside ca
    Local Time:
    3:47 AM
    Thanks for the responses
    Do you have any pics?
    • Like Like x 1
    • Toycrash
      Toycrash New Member
      4
      7
      Nov 19, 2017
      Finland
      Local Time:
      11:47 AM
      • Like Like x 2
      • jedrattle
        327
        91
        Jul 31, 2005
        Riverside ca
        Local Time:
        3:47 AM
      • moparmat2000
        moparmat2000 FABO Gold Member FABO Gold Member
        18,838
        7839
        May 13, 2010
        Grand Tetons
        Local Time:
        3:47 AM
        I am seriously leaning towards the EPS setups now. If i can find a really good thread that details this for a 67-69 A body column i may just do this. I heard toyota yaris is the smallest one that will fit.
      • MonkeyMadness
        MonkeyMadness Well-Known Member
        1,012
        1161
        Jun 13, 2016
        Yorba Linda California
        Local Time:
        1:47 AM
        Wow that was time...
        Back and looking to make some progress.
        Pulled the motor and trans lastnight.
        Gotta swap the head gaskets to a more boost friendly gasket.
        Was looking into sending the trans out for rebuild, that's was until i got a few quotes, $2200 to $1600. Guess what I'm doing next :realcrazy:
        Yep cracking it open, placing and order for a master rebuild kit performance "2" Grrr...
        20190708_184308.jpg Also got my heater box rebuilt and ready to go. Acquired the needed heater controls. So thats set and done. (pictures not included)
        Also while day dreaming about a much needed drive in this car I decided I'd keep a bit of old school touch along with my stock shifter and now that i have the epas unit I bought an old Fury GT wheel that i fell in love with... no its not year correct. Nope not a tuff wheel like everyone else. But hey who gives a shit I like it and its staying. :p
        • Like Like x 6
        • Keith Mopar
          Keith Mopar Mopar Nut
          3,178
          1747
          May 15, 2005
          Calgary AB.
          Local Time:
          2:47 AM
          Great progress, I'm amazed you got it all out with the rad still in place!
          • Thanks! Thanks! x 1
          • Agree Agree x 1
          • MonkeyMadness
            1,012
            1161
            Jun 13, 2016
            Local Time:
            1:47 AM
            right.. I've pulled it soo often I've gotten really good at pulling it in and out with out issue. This will all change once I get the front of the engine on belt n pulleys and stuff...
            • Like Like x 2
            • Biff
              Biff Cheep not easy
              7,254
              15394
              Jan 30, 2017
              Canada
              Local Time:
              1:47 AM
              Hey MM. the hardest thing to put back together on that tranny is getting that shift rod in the right place in the O.D. Unit . When you assemble the O.D. Unit it self all the clutch plates have to line up so use the input shaft to line up all the guts , there easy nothing oddball , have fun looking foward to progress picks.
              • MonkeyMadness
                1,012
                1161
                Jun 13, 2016
                Local Time:
                1:47 AM
                So just purchased a rebuild kit for this 46RE and I got "all the bells and whistles".
                Now I have to build a simple press tool for the over drive and reverse spring and "c" clips.
                the damn thing is under 640+ lbs of pressure ugh...
                I found a lot of vids on youtube showing how to rebuild this. One in particular is a School or factory tech series of vids on the complete tear down an rebuild of this transmission. He talks real and points out everything so dummies like me can even follow. It's not too much different from the 727 / 904 :poke:
                So i feeling pretty confidant about it right now. :realcrazy:
                • Like Like x 3
                • Jadaharabi
                  Jadaharabi FABO Gold Member FABO Gold Member
                  8,760
                  9724
                  Jan 8, 2016
                  Peoria, Illinois
                  Local Time:
                  3:47 AM
                  Take the overdrive unit and the rebuild parts for it to a tranny shop. They have the tools to do the job and they can do it quickly.
                • belmateo
                  belmateo Well-Known Member
                  1,860
                  271
                  Mar 29, 2008
                  Belmont, California
                  Local Time:
                  1:47 AM
                  Have you decided how you are going to switch on the overdrive and lock up the converter?
                • MonkeyMadness
                  1,012
                  1161
                  Jun 13, 2016
                  Local Time:
                  1:47 AM
                  Yes. I'm not running the "RH" trans, I have the "RE" everything is elc. controlled. I'm running the OBD2 fueling injection w/ harness and trans control. All will be tuned by Ryan at Flyin Ryan Performance, He'll be setting fuel map and shift points as well as lock converter and overdrive.
                  • Like Like x 3
                  • JDMopar
                    JDMopar Well-Known Member
                    3,922
                    2871
                    Jan 19, 2012
                    Candler, NC/Myrtle Beach, SC
                    Local Time:
                    4:47 AM
                    Everything's looking good. Did the Saturn EPS clear the wiper linkage more than it looks like it does? Pics can be deceiving...lol. Don't let that OD spring bust your brains out!
                    • MonkeyMadness
                      1,012
                      1161
                      Jun 13, 2016
                      Local Time:
                      1:47 AM
                      Haha right. Thats my biggest worry at the moment. In the midst of building a compression tool to use with the press. Bit of welding and I'm done.
                      Edit: @JDMopar to answer your question, Yes it clears the wipers unit and movement fine. Remember though I'm not using the stock parking brake and with that removed I was allotted a lot more room just to the left of the unit allowing me to rotate it more to the left allowing for the room around the wiper transmission and arms
                    • MonkeyMadness
                      1,012
                      1161
                      Jun 13, 2016
                      Local Time:
                      1:47 AM
                      Worked like a charm...
                      Master rebuild kit should be here tomorrow.
                      • Like Like x 6
                      • 75slant6
                        75slant6 Well-Known Member
                        5,578
                        2091
                        May 15, 2011
                        Russellville, ky
                        Local Time:
                        3:47 AM
                        Some people just have all the ingenuity... lol
                        • Like Like x 1
                        • JDMopar
                          3,922
                          2871
                          Jan 19, 2012
                          Local Time:
                          4:47 AM
                          Wow....that thing is slicker'n cat poop on linoleum....lol. Isn't there a big snap ring that holds the OD part together? I just know that the guy who used to rebuild Torqueflites for me was scared to death of those springs...lol. Good idea on the E brake mechanism. Are you going to use a foot pedal, or a hand thing on the hump? I'm going to use an E body foot pedal in my 70 Duster.
                        • MonkeyMadness
                          1,012
                          1161
                          Jun 13, 2016
                          Local Time:
                          1:47 AM
                          Yes the first one ( 1 ) lower snap ring is the clutch pack for the over drive and the second one ( 2 ) is the inner planetary spring snap ring.
                          As for the e-brake i was planning on using a line lock setup for the rear with a dash mounted dial/switch maybe?
                        • JDMopar
                          3,922
                          2871
                          Jan 19, 2012
                          Local Time:
                          4:47 AM
                          Gotcha on the snap rings, I see now! We used to have an electric setup for holding the brakes on some of our service bucket trucks at work. It was called a Mico Brake. You held the brakes down, and flipped a switch on the dash, and it locked the back brakes down. Worked really well, but if you left it parked like that for a long time, it would drain the battery because the switch must have kept using voltage to hold the solenoid closed to keep the brakes applied. Way back in the day, we had an earlier version of the Mico Brake that you just pumped the brakes up tight and then closed a valve, and it held the brakes hydraulically. Keep up the good work!
                          • MonkeyMadness
                            1,012
                            1161
                            Jun 13, 2016
                            Local Time:
                            1:47 AM
                            Made some good progress this weekend. I was able to fully rebuild the over drive unit, swap the out put shaft for a one with a speedo drive and now prepped for the press. I also completely torn down the case and parts ready for rebuild. Once I have the OD unit finish I can start the main unit rebuild.
                            • Like Like x 3
                            • belmateo
                              1,860
                              271
                              Mar 29, 2008
                              Belmont, California
                              Local Time:
                              1:47 AM
                              Looking good, the rebuild is pretty straight forward as long as you do not open the valve body.
                            • MonkeyMadness
                              1,012
                              1161
                              Jun 13, 2016
                              Local Time:
                              1:47 AM
                              So got the overdrive planetary and spring pack finished. I can now drop the OD unit in the tail housing and finish that end. Which means I will be starting the rebuild/ assembly of the main case, But to do that I needed a trans stand to hold the case upright to drop in the gut of the tranny. This dude online shows how to build it out of 2x4 and it turned out pretty good. I'm 6'4" soo it could have been a bit taller to save my back but what ever.. lol
                              20190716_201502.jpg 20190716_203627.jpg 20190716_203815.jpg 20190716_203805.jpg
                              • Like Like x 5
                              • MonkeyMadness
                                1,012
                                1161
                                Jun 13, 2016
                                Local Time:
                                1:47 AM
                                Crap.. I forgot to take more pictures last night only got the one. I'll take more tonight. I might have the internals finished tonight as well. Now I'm thinking since I'm in here and not interested in opening this back up, maybe I should install a shift kit with the rest of the upgrades I have already done to this trans.?
                                Well I got the OD finished and OD servo rebuilt, front and rear cases are matched. "inner-output" shaft, new reverse band, and drum installed. I've replaced all the servos and band actuators with built upgrades, new bands. Tonight I'll try and finish the guts ( 1/2/3/R) of the trans.
                                ugh only picture I took last night....
                                • Like Like x 3
                                • RogerRamRod
                                  RogerRamRod The Older I Get, The Faster I Was
                                  960
                                  581
                                  Jul 5, 2011
                                  Chesapeake VA
                                  Local Time:
                                  4:47 AM
                                  Could you post some links to the most helpful of the videos you've found please? I think I will be needing to do this, and I'm tired of having to sort through 4 or 5 bullshit videos to actually find one that is actually helpful for each of the projects I've tackled.
                                  • Like Like x 1
                                  • MonkeyMadness
                                    1,012
                                    1161
                                    Jun 13, 2016
                                    Local Time:
                                    1:47 AM
                                    Sure thing!
                                    Here is the youtube page: Transmission Bench
                                    and this is the start to the 46re Build:
                                    I watched the whole video set/class before I started my build. Made it super easy and understood everything. I also had/have my laptop in the garage while building and just kinda follow along with my build. make it soo easy even a caveman can do it!
                                    • Thanks! Thanks! x 3
                                    • Like Like x 2
