1965 MMP's Barracuda Project "Disco Volante"
Members Restorations
  1. MonkeyMadness
    MonkeyMadness Well-Known Member
    1,012
    1161
    Jun 13, 2016
    Yorba Linda California
    Local Time:
    12:25 AM
    Had a busy day but got some time in the garage.
    I got the bearings greased up and disc's on. Calipers not yet but I was able to bolt the wheels on. I had preplanned and had the spacers, I have 1/2" spacer for the fitment I was looking for.
    These are pictures of the wheels on and suspension as low as it could go. I love how it looks now but I will be raising it up just a few inches for the street. :D
    20191230_194858.jpg 20191230_194913.jpg 20191230_175743.jpg 20191230_175813.jpg 20191230_174939.jpg 20191230_175817.jpg 20191230_175825.jpg
    • Like Like x 7
    • Thanks! Thanks! x 1
    • MonkeyMadness
      1,012
      1161
      Jun 13, 2016
      Local Time:
      12:25 AM
      Better pictures of how it sits at the moment.
      IMG_20191231_151314_808.jpg IMG_20191231_151314_806.jpg IMG_20191231_151314_805.jpg
      • Like Like x 5
      • 89on35s
        89on35s Inferno Red Duster FABO Gold Member
        1,874
        1980
        May 11, 2006
        Martensville Sask. Can.
        Local Time:
        1:25 AM
        That car is awesome!
        Cley
        • Agree Agree x 2
        • MonkeyMadness
          1,012
          1161
          Jun 13, 2016
          Local Time:
          12:25 AM
          Sorry forgot to add the side shots too 20191231_152248.jpg 20191231_152302.jpg
          • Like Like x 3
          • Fred Scigliano
            Fred Scigliano Off center a bit
            17,643
            26073
            Nov 26, 2017
            NORTH DAKOTA
            Local Time:
            2:25 AM
            • Agree Agree x 1
            • 75slant6
              75slant6 Well-Known Member
              5,578
              2091
              May 15, 2011
              Russellville, ky
              Local Time:
              2:25 AM
              • Agree Agree x 1
              • MonkeyMadness
                1,012
                1161
                Jun 13, 2016
                Local Time:
                12:25 AM
                So all of my travailing for now is done, and I was able to spend some good time in my garage this weekend making some progress on the car.
                No issues to speak of other than I had to notch my trans mount bracket to allow for the OD speed censor. Other wise it all just fell together as expected...
                20200301_104406.jpg 20200301_104412.jpg 20200301_114859.jpg 20200301_114912.jpg 20200301_114917.jpg 20200301_114951.jpg 20200301_161009.jpg 20200301_161022.jpg
                • Like Like x 10
                • MonkeyMadness
                  1,012
                  1161
                  Jun 13, 2016
                  Local Time:
                  12:25 AM
                  I do have a question for anybody who may know. My current belt setup should I be worried out my belt on the drivers side of the block? Should i leave it or run an added idler pulley?
                  • Like Like x 3
                  • Bodyperson
                    Bodyperson Pedal to the metal FABO Gold Member
                    6,073
                    8521
                    Nov 26, 2015
                    NW MONTANA
                    Local Time:
                    1:25 AM
                    It does seem like a lot of deflection. Running it will be the answer.
                    • Like Like x 1
                    • Agree Agree x 1
                    • replicaracer43
                      replicaracer43 Grumpy Old Man
                      4,780
                      4031
                      Oct 10, 2008
                      Local Time:
                      2:25 AM
                      Belt short enough? That side will be under load when running, so as long as belt has tension from tensioner, I'd think you would be ok
                      • Agree Agree x 1
                      • MonkeyMadness
                        1,012
                        1161
                        Jun 13, 2016
                        Local Time:
                        12:25 AM
                        It's just a mochup at the moment. I didn't want to order a belt till i had the right size i needed..
                        • Agree Agree x 1
                        • TT5.9mag
                          TT5.9mag Two atmospheres are better than one
                          986
                          938
                          May 5, 2016
                          So cal
                          Local Time:
                          12:25 AM
                          Looks like you have a lot of wrap, which is good. But supercharger belts love to slip. That is a long run and will probably cause slipping. I would find a way to run more tension or add an idler. Love your build.
                        • MonkeyMadness
                          1,012
                          1161
                          Jun 13, 2016
                          Local Time:
                          12:25 AM
                          Got my front end sorted out, and some parts in. Thanks to another memeber here I was able to get some A-pillars for the build (I been collecting all the interior parts)
                          Also got new 67 disc brake lines and PST tie rods,
                          Moog ball joints and put my steering together.
                          Had to shim the motor mounts and bit dinged my oil pan a tad on the drivers side.
                          Next I'll paint the calipers, and install the front brakes, plum the lines and sort out my oil lines to the remote filters and coolers.
                          20200320_122043.jpg 20200320_122028.jpg 20200323_175651.jpg 20200323_175847.jpg 20200323_175622.jpg
                          * I know the tie rods are on the wrong side* :BangHead:
                          • Like Like x 4
                          • RustyRatRod
                            RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
                            70,764
                            45678
                            Jun 7, 2010
                            Georgia
                            Local Time:
                            3:25 AM
                            Very nice build. About the belt.......look how it routes the water pump. See how much pulley engagement it has? Over half way around. IMO, you should try to shoot for that around the blower pulley, too. I don't think the long run will hurt, but the more pulley engagement you can get there, the less chance it has for slippage. It may surprise you with slippage........I wouldn't think so.....but a belt driven supercharger takes a bit to drive. If you can add or move an idler for more pulley engagement, I'd try it.
                            • Like Like x 1
                            • Agree Agree x 1
                            • Fred Scigliano
                              17,643
                              26073
                              Nov 26, 2017
                              NORTH DAKOTA
                              Local Time:
                              2:25 AM
                              Had to shim my engine mount and ding the header over the steering box so looks like I'm not the only one making things fit. Looking good a sweet ride it will be...
                              • Like Like x 1
                              • MonkeyMadness
                                1,012
                                1161
                                Jun 13, 2016
                                Local Time:
                                12:25 AM
                                Not much of a update, haven't been in the garage much. I did get to spend time last night and installed my calipers. Hoping I get time and motivation enough to install all the brake lines this weekend.
                                I was able to get the needed heater box parts for install, just need to build the J hook and I should be able to install that. Also ordered the tail light harness for the car. Got so much going on and figured I would be better off completely rewiring the car. So now I have all 3 body harnesses, EFI harness. Going to need to build a fuel pump harness, battery relocation wiring (to the trunk). My plan is to install the two body harnesses firewall forward and dash back harness. then splice in the efi harness to the firewall forward harness. Then install the dash harness to dash (out of the car) splice in the Dakota digital gauge pod and EPAS unit.
                                Side Note: I've been buying up all the interior pieces I can find and I'm found that I need the rear lower Driver side window molding if you got one or a set you would like to sell let me know I'm in need.
                                Covid-Cocktail n Boost
                                • Like Like x 9
                                • ValerianMagnum
                                  ValerianMagnum the little car that could
                                  845
                                  97
                                  Mar 17, 2008
                                  montreal , canada
                                  Local Time:
                                  2:25 AM
                                  to be honest , its one of the nicest build ive seen in my life , im doing a 5,9 + 46re in my 71 cuda , all stock for extreme reliability . your barracuda is an awesome awesome built and i love how the custom parts ! very inspiring !!! keep the good work buddy
                                  • Agree Agree x 1
                                  • ValerianMagnum
                                    845
                                    97
                                    Mar 17, 2008
                                    montreal , canada
                                    Local Time:
                                    2:25 AM
                                    How will you manage to run a efi system that can read the supercharger ? ( and from what car doest come from ? )
                                  • MonkeyMadness
                                    1,012
                                    1161
                                    Jun 13, 2016
                                    Local Time:
                                    12:25 AM
                                    I'll be running a stock ECU and Harness from a 98 Ram 5.9. The Harness was modified by MagnumMopar, and the ECU is tuned by a guy named Flyin Ryan Performance
                                    the Throttle body is 90mm GM unit with GM TPS, Neon SRT4 -2bar Map sensor, 60lbs (short) high impedance injectors, walbro 255lph in-tank fuel pump, and a corvette fuel fliter/regulator....
                                    The SRT4 Map sensor will go in place of the stock Ram map sensor. Although it won't be on be located on the Throttle body like the ram it will be mounted to the manifold reading the vac/boost from beneath the SC.
                                    This guy Ryan is a freaking wizard with tuning these damn mopar efi's. If this is the route you plan to take I suggest joining his face book group and reading his web page and get a hold of him tell him your intentions and he'll Help you with pretty much everything.
                                    Log into Facebook | Facebook
                                    FRPTuning / Flying' Ryan Performance
                                  • MonkeyMadness
                                    1,012
                                    1161
                                    Jun 13, 2016
                                    Local Time:
                                    12:25 AM
                                    One of my resent posts I mentioned I was gearing up to start the wiring of the barracuda and waiting for the final harness from yearone, and it got me thinking about one thing I had over looked. The sound system so I picked up this sweet early 60's Mono Am radio from 75slant6 Thank you sir!
                                    Last weekend I dropped the Barracuda's mono Am radio off at Hector's Car audio tech
                                    for the royal treatment. It's getting fully built with Aurora Design internals. Am/FM upgrade with 4 Speaker jack, Bluetooth, 180amp output all in the 1960's package.
                                    Aurora website --> Home
                                    94160711_2835850259856479_7180461380699422720_n.jpg 94134706_2835850563189782_2826742612877115392_o.jpg 94092732_2835850353189803_8315048305574805504_o.jpg 94138395_2835850673189771_6880878482566414336_n.jpg
                                    • Like Like x 2
                                    • JDMopar
                                      JDMopar Well-Known Member
                                      3,922
                                      2871
                                      Jan 19, 2012
                                      Candler, NC/Myrtle Beach, SC
                                      Local Time:
                                      3:25 AM
                                      :thumbsup: You're getting closer every day! I thought Magnum Mopar went out of business? Did he do your harness before that? I've heard others say good things about Flyin Ryans tunes.
                                    • MonkeyMadness
                                      1,012
                                      1161
                                      Jun 13, 2016
                                      Local Time:
                                      12:25 AM
                                      Yes I had them do it before. It was one of the first thing I bought after picking up the motor.
                                      Yea Ryan's a cool dude everybody has nothing but good shit to say about him
                                    • MonkeyMadness
                                      1,012
                                      1161
                                      Jun 13, 2016
                                      Local Time:
                                      12:25 AM
                                      Got to spend all day in the garage today. Spent a lot of time pulling the car an all the projects out of the garage to clean it out.
                                      Then I took the time to completely strip and clean the inside of the barracuda, vac the whole car. pulled everything out tagged and bagged all the old harnesses, removed all the old carpet it was nice being able to get a lot of the car sorted out.
                                      While doing that ups Dropped off my Master cylinder relocation block which allows my to mount my brake booster about 3/4" to the left. Giving me the space I wanted between my valve cover and booster. Once I can get that sorted I'll be able to get my brake lines installed..!
                                      I also took the time to pull out the EFI fuel tank kit I've been sitting on for a few minutes. Man this thing is cool, it didn't take to long to get setup. Had a fun day today..
                                      20200502_113320.jpg 20200502_115313.jpg 20200502_115434.jpg 20200502_115440.jpg
                                      20200501_185933.jpg 20200501_185959.jpg 20200501_190006.jpg 20200501_190012.jpg 20200501_201845.jpg 20200501_205948.jpg
                                      • Like Like x 1
                                      • MonkeyMadness
                                        1,012
                                        1161
                                        Jun 13, 2016
                                        Local Time:
                                        12:25 AM
                                        20200501_190006.jpg 20200501_201748.jpg 20200501_201813.jpg 20200501_205957.jpg
                                        • Like Like x 2
                                        • JDMopar
                                          3,922
                                          2871
                                          Jan 19, 2012
                                          Local Time:
                                          3:25 AM
                                          The tank is nice. Are you going to use the side to side strap like the car came with, or switch to front to back straps to hold the tank in? On my 65 Barracuda, I'm going to switch to the later type straps to gain some room for dual tail pipes. There won't be much to making the mounts.
