[FOR TRADE] 1967 bucket seat tracks
Mopar Trader
Thread Status:
  1. Jmill67
    Jmill67 Active Member
    37
    9
    Apr 20, 2019
    California
    Local Time:
    3:20 AM
    Contact Seller
    I have an excellent set of 67 A-body bucket seat tracks that I want to trade for a 67 B-body set. Prefer no broken studs or major rust.
  2. Sedanman
    Sedanman 67-9 Valiant specialist FABO Gold Member
    8,591
    601
    Apr 3, 2009
    chicago Il
    Local Time:
    5:20 AM
    Why not just use what you have and move the stud to the B body position?
    • Agree Agree x 1
    • Jmill67
      37
      9
      Apr 20, 2019
      California
      Local Time:
      3:20 AM
      If that’s the only difference, then I’ll do that. I’ve never seen a set side-by-side, so I never knew what would change between the 2 different body styles. Have you ever performed the changeover?
    • Sedanman
      8,591
      601
      Apr 3, 2009
      chicago Il
      Local Time:
      5:20 AM
      The seat frames are the same for A,B and most C bodies and so are the tracks. If you look at the track there should be multiple square holes where the stud gets welded
      • Thanks! Thanks! x 1
      • Jmill67
        37
        9
        Apr 20, 2019
        California
        Local Time:
        3:20 AM
        Thanks Sedanman! That’s some good info right there. Much appreciated!
      • Sedanman
        8,591
        601
        Apr 3, 2009
        chicago Il
        Local Time:
        5:20 AM
        Did you find the holes?
      • Jmill67
        37
        9
        Apr 20, 2019
        California
        Local Time:
        3:20 AM
        Yep. Several different sets of square holes. Looks pretty easy. I shouldn’t have any problem moving them over and swedging them into place. Thanks again!
        • Like Like x 2
        • moparmat2000
          moparmat2000 FABO Gold Member FABO Gold Member
          16,796
          5831
          May 13, 2010
          Grand Tetons
          Local Time:
          5:20 AM
          I had no idea. Is this the same A body track setup from 67-72 with the multiple carriage bolt holes?
          • Like Like x 1
          • Sedanman
            8,591
            601
            Apr 3, 2009
            chicago Il
            Local Time:
            5:20 AM
            Your welcome,Ma Mopar being frugal has it's benefits lol
            • Agree Agree x 1
            • moparmat2000
              16,796
              5831
              May 13, 2010
              Grand Tetons
              Local Time:
              5:20 AM
              Yes, thank you so much. That certainly will help some people. I have all the tracks i need for 2 cars but its good to know.
            • Sedanman
              8,591
              601
              Apr 3, 2009
              chicago Il
              Local Time:
              5:20 AM
              I'm pretty sure,just look for the multiple locating holes in the track frame. The seats were shared between A,B,E and c bodies. The year has to match though like 67-9 A,B<C ,70-1 A,B,E, maybe C ,72-4. I'm not sure how long they kept doing it that way but I had many 67's to early 70's seats with the holes. The 66 seat sliders also had tilt and raise/lower built into them
            • Sedanman
              8,591
              601
              Apr 3, 2009
              chicago Il
              Local Time:
              5:20 AM
              I have 73-4 B seats and I think they are the same tracks as E.
            • RedFish
              RedFish Well-Known Member
              24,417
              2975
              Sep 5, 2007
              Local Time:
              5:20 AM
              I'm not going to disagree with above but I will share some personal experience.... Our first 67 B'cuda notch was a bench seat car. In 1982 I found a 67 Sport Fury in a local parts yard. I bought those buckets ( along with floor shifter, etc..) for my notch.
              The tracks under these buckets were made much like the pre 67 a-body tracks. The bottom half of the tracks were 2 pieces with square head hardware through stepped slots that allowed height/angle adjustments. I took those tracks completely apart, turned them 6 ways from Sunday and still needed a spacer under one corner to get them bolted into the fish. Do 67 a-body tracks work better in 67 b-body than 67 b-body tracks work in 67 a-body? I have my doubts. Good luck though.
            Thread Status:
