Testing the waters here. I don't need to sell but considering buying a new house.
1967 Dodge Dart GT
Body is in fair condition. All the wiring was good as this was basically driving when I tore it down to restore.
I have $3,500 in amd sheet metal for this car.
Inner rockers and full amd floor installed.
One fender apron cut out and fit up.
Comes with good condition tail panel, multiple sets of trunk trim.
Set up for a 440/727-Two sets up Schumacher mounts-and one Trans dapt
A body 8 3/4 with new drums and rebuilt brakes. 741 non sure grip center. Comes with rebuilt 67 Sure grip clutch unit
B&M trans cooler new in box
Mopar performance black wrinkle valve covers and air cleaner
78 440 and matching 727. Motor is torn down to bare block but have rods and pistons. Trans is still fully complete.
Brand new custom made drive shaft
Brand new mancini racing springs, shackles, shocks, brake lines, spring hangers, and shock plates.
I have all of the 67 GT Trim and some additionals.
4 NOS Fender marker lights
Has small bolt pattern ralleys
Rear drums-Front drums 10 inch w/cooling fins from 73 and up-Easy to swap to discs now with 73 and up control arms included.
2 67 Hoods 3 67 Doors
Black buckets-fair condition-rear seat fair
New fuel tank, gas cap, and filler tube
Cold Case 26 inch radiator
This car was tagged in the RT quarter and lock pillar but I have ALL of the sheet metal to replace everything.
This is originally an A/c car and have most of the parts for that if you desire.
Everything goes with. Package deal. This is a great project because it basically has everything you need to just build the car other than how you'd like the engine done.
Schumacher Tri Y big block headers new in box.
I literally have shelves of brand new parts for this build.
Located in Southern Wisconsin.
I'm guessing I have close to 15k in parts for this car and 3k in the body so I won't take any low ball offers.
15k Takes it all home. If not I will stash away and fix it another time.
This is a resto thread I had going for the car.
Project "Pig Pen" 1967 Dart Gt
1967 Dodge Dart GT
