1968 Fast Back Tires 60's vs 50's
Mopar44134
Ohio
I've read through a couple of old threats and the consensus is you can fit a 275/60/15, you may have to add a spacer to center the tire but doable without cutting or relocating.
I' m looking at the Mickey Thompson ET street SS. The 275/60's state section width is 11.10" with a 9.29 tread. The 275/50's state 11.10" with a 10.2 tread. On paper I figured i should have 1/4 clearance to the spring, 1/2 fender.
So in theory, 50's should fit????????????
Mine fit perfect!!
