I had the top replaced well over a year ago on a 1970 300. The car went directly into the garage with the top down. I wanted to do several things to the car and have completed them however the top seem way too tight. I cannot latch it and have found that the the installer broke one of the latch hinges and also broke one of the bolts on one of the main mounts. I am not interested in bringing it back to this person. Right now I have it so the top is hooked at the latches hoping it will stretch over time. I've not had a day where I can put the car in hot sun to help stretch it so is there any other method I can use to help? The top is so tight that the rails are more than 1" from the glass. I did all the adjustments in the FSM other than the "Stack Height" which is done at the rear mounts. I don't understand what stack height refers to so if someone knows and could pass the meaning on I would greatly appreciate this as I would any advice on getting the top to fit properly.
Thanks-Howard
Thanks-Howard
