[SOLD] 1970 Swinger 340
Moparbrad
You don’t know me
Phoenix,AZ
Rating - 96.8%
30   1   0
This is a real 340 4 speed swinger. The car is a southwest native so rust isn’t an issue. Just needs the lower quarters replaced. I have nice lower quarters cut off a parts car included. Upper radiator support is cut but I have an NOS one included.
Bench seat, 4 speed, manual everything, green on green car.
Missing the original engine and trans. Included is a standard bore, non vin stamped 1970 340 engine that is disassembled. Has big valve J heads, rods and pistons, windage tray, oil pan, 70 dated timing cover, 340 Carter AVS carb, correct valve covers and air cleaner and LD340 intake. Have a 4 speed trans, I believe it’s a 69. Have the bell housing, shifter and linkage! Have the correct length drive shaft too. Original radiator and fan shroud. Complete rallye wheels with center caps and trim rings. Still has the 8 3/4 rear end, front disc brakes (calipers are in the trunk), rallye dash is cut for radio, have the factory radio, 4 speed hump is cut up but repairable. The car has the dash vin, fender tag and clean title.
I’ve been busy lately but I will work on getting more pics, probably next weekend.
$7500 located in Phoenix, AZ.
It has the standard equipment. Only options were front eye brow moldings, wheel lip moldings and white butt stripe. Rallye dash and disc brakes were standard on the 1970 340 Swinger.
Would you sell as a roller with the drive shaft, rad , rad shroud, valve covers, air cleaner , steering column all interior parts you collected Carter AVS carb nothing else and for how much $$$.
So you mean everything for the car minus the block and transmission?
Would consider trade/partial trade for a V8 1970 Swinger driver or 1971-1972 Scamp. No eng or trans is fine too. Wrecked is okay too. No rust buckets.
More
The hood is damaged but I’m including another hood. The trunk lid has a small rust hole but I have a better one to include as well.
So the quarter patches are gone and the air cleaner is being used somewhere else. Make me an offer on the car as is or no eng/trans parts.
I can also transport to most places in the country cheaper than the big guys.
