1972 225 /. Fuel line help?
Slant 6 Engines
  1. Tduff01
    Tduff01 Well-Known Member
    116
    2
    Jun 3, 2014
    Brookville, Indiana
    Local Time:
    12:28 AM
    I have a 1972 225 /6 from my duster. Looking for a fuel line from the pump to carb, (single barrel holly). Found one on summit that says work. Just wonder if anyone has used it or knows of one that will work. Several years ago I had to replace the fuel pump I had to make a new fitting for the fuel line at the fuel pump because 1- it didnt line up with the new pump and 2- the fuel line was cut and had a rubber line spliced in. So I put a new fitting and ran a rubber line from the pump to carb. Having to change the fitting and stuff then, is what makes me wonder if this will fit. Thanks everyone.
  2. halfafish
    halfafish Damn those rabbits, and their holes! FABO Gold Member
    1,696
    1495
    Aug 14, 2016
    SW Washington
    Local Time:
    10:28 PM
  3. Tduff01
    116
    2
    Jun 3, 2014
    Brookville, Indiana
    Local Time:
    12:28 AM
    Heres pics on the pump and carb.
  4. Tduff01
    116
    2
    Jun 3, 2014
    Brookville, Indiana
    Local Time:
    12:28 AM
  5. 1963dartgt
    1963dartgt FABO Gold Member FABO Gold Member
    803
    338
    Nov 7, 2015
    Kansas
    Local Time:
    12:28 AM
    The fuel line mod is leagues better than the original routing and itll save you some money. Just dont run a glass or plastic filter.
