Will they work with 73 LBP conversion?
It is a dart swinger that came stock with disk brakes.
I want to use 5x4.5" wheels.
This is my first rodeo with an A body. A lot I don't know.
I think a 72' with a 7 1/4 diff had 9" rears.If your rear SBP 10 x 1.75 drums are good they are worth money also...
Hemi71x - who is that supplier? I did not know that.
Are you aware that there is a vendor that re machines early Ford Mustang rotors with 4 1/2 inch bolt pattern, that will then work on a Mopar spindle?
Took the drums over to my local shop, one has .030 left. The other .040.
The drums have a cooling flange, makes the drum look like an old German army helmet is the best way to describe it.
