[FOR SALE] 1973 340 Engine
408 swinger
Iowa
1973 340. Std. Bore. Crank is 10/10. Rods look to have been recon'd. Possibly internal balance. I received this in a big parts buy. I didn't build it, nor did the guy I bought it from. WYSIWYG. Needs disassembled and cleaned. No timing set. Heads need to be gone through. 2.02 J castings. No tins or timing cover. I do have those from different engines that can be negotiated in. Can put on a pallet and drop at Fastenall. $1500.00 OBRO. PM me here. Thanks, FABO!!
This would make someone a very economical 340. Disassemble, clean, put back together. Bearings are new. Rings are new. It just sat uncovered for many years. Cylinders are fresh and just need cleaned, not re-honed, CLEANED.
