1973 duster 340 will not start- no start
Electrical and Ignition
  1. beerboy
    beerboy Well-Known Member
    116
    131
    Oct 30, 2013
    rochester n.y
    Local Time:
    11:52 PM
    ok after storing my 73 340 duster, since November, I am having a fire up issue. car was running great when put away in an unheated garage. full tank, stabil all that good stuff, battery was on a tender and the car cranks , with oil pressure, but refuse to fire. getting gas in carb. no spark. ok, I changed the ballast resistor. still nothing. where would you guys look at next, and what order??
    orange box shot?
    coil shot?
    distributor cap cracked?
    plug and coil wires are pretty new
    bad ground on box? worked before
    bad connections under dist. cap?
    any other wires I should look at?
    getting frustrated so whats #1 to look at and so on
    thanks much for any kind of help:sad1:
  2. Bad Sport
    Bad Sport HALF A BUBBLE OFF Staff Member FABO Gold Member
    39,606
    22293
    Jun 12, 2010
    The Wolverine
    Local Time:
    11:52 PM
    As I suggested in your other post, pull the cap and check the rotor, cap etc for corrosion.
    It's an easy step.
    • Like Like x 1
    • Tribute SS/A 68
      Tribute SS/A 68 Well-Known Member
      401
      86
      Jun 30, 2009
      Little Rock
      Local Time:
      10:52 PM
      Simple process of elimination, get a test light, turn on key, see if you have power at ballast rist. should have done this first. If power is there, follow the power to coil, then to dist, if no power at BR, you have to go under dash to key switch.
      • Like Like x 1
      • abodyjoe
        abodyjoe Well-Known Member
        21,642
        7429
        May 22, 2004
        Berlin,N.J. 08009
        Local Time:
        11:52 PM
        with that garbage ass orange box on it thats where i would have looked first.
        if you have an extra box laying around (i always have an extra box and ballast in the trunk) then give it a try.
        i'd check grounds and connections. no telling what may have corroded over teh winter..
        • Like Like x 1
        • beerboy
          116
          131
          Oct 30, 2013
          rochester n.y
          Local Time:
          11:52 PM
          which box would you go with? I hear the chrome is for hi reving race motors. so whats best for street use
          ? thanks
        • abodyjoe
          21,642
          7429
          May 22, 2004
          Berlin,N.J. 08009
          Local Time:
          11:52 PM
          me? i went with a nice one from napa.
          • Like Like x 1
          • beerboy
            116
            131
            Oct 30, 2013
            rochester n.y
            Local Time:
            11:52 PM
            went on the napa website and can,t find an ecu box. do you have a part #? 73 340 engine
          • abodyjoe
            21,642
            7429
            May 22, 2004
            Berlin,N.J. 08009
            Local Time:
            11:52 PM
            • Like Like x 1
            • beerboy
              116
              131
              Oct 30, 2013
              rochester n.y
              Local Time:
              11:52 PM
              as I was saying , put an inline tester in plug wire and got nothing. could a coil or ecu box just go from the cold or from sitting all winter? seems crazy to happen, still have to check cap and rotor
            • green1
              green1 Well-Known Member
              4,668
              19
              Dec 6, 2008
              Orange Park, Fla
              Local Time:
              10:52 PM
              As was stated; check grounds(all), then test light from key forward.
              • Like Like x 1
              • beerboy
                116
                131
                Oct 30, 2013
                rochester n.y
                Local Time:
                11:52 PM
                got it running moisture under cap and cleaned up a ground!! thanks for all help
              • rebelcaptain
                rebelcaptain Member
                10
                1
                Apr 18, 2014
                Batavia, NY
                Local Time:
                11:52 PM
                why do you say that chrome box is just for hi rev motor and orange box is junk?
              • AdamR
                AdamR Big Member
                17,765
                365
                Dec 31, 1969
                Bethel, CT
                Local Time:
                11:52 PM
                The orange boxes are known for having issue. Short life if they even work right about of the package. The Chrome box is fine for a street car but I would think the quality is the same as the orange box.
