bbrroowwnn
never re member
I have a 360 short block consisting of bottom end rotating assembly and a set of 4027596 heads...Both heads are there...I just have the one off for the pictures......no rocker assemblies though....It comes as pictured....stock bore....block is dated 4.22.79 the 4 may also be a 1 or 7...not sure...casting number is 4179930-360-10? I took the one head off to get some better pictures....good buildable core if you are looking to build a 360.....I would like a local pickup on this....200.00 OBO
