David Musselwhite
Did the automatic transmission in a 1983 dodge 1 ton truck get in xtra goodies. Maybe a xtra low first gear or 4 pinion planetary?
Wasn't the loadflite a pre-torqueflite transmission from the 50s used on the 1st gen hemis?
1 ton absolutely 4 gear front and rear planetaries !!Did the automatic transmission in a 1983 dodge 1 ton truck get in xtra goodies. Maybe a xtra low first gear or 4 pinion planetary?
