joe not sure if your belv floor will need a little hammering or not,,,there is a company that has a complete kit switches and pressure switches to do this conversion,, its about 85 bucks for the complete kit,,i may have it saved if ur intrested,,,,
you can put it all on 2 toggle switches,,but you would have to kick the over drive and the lock up off every time you came to a stop,,,manually,,
with the kit, you choose the speed of travel you would like the over drive and lock up to turn on,,,once you select that, when you slow to a speed under your selection , the lock up and over drive kicks off,,you can also put the over drive kick off on the brake pedal,,,,,
if i was farther along in my street rod ide grab this trans
