2.02 heads on a 318
jrlegacy23
68 Barracuda
Laurens, NY
I have heard that you can not put 2.02 heads on a 318, is this true, or can you bore it .030 over and fit them on? I am looking to Aluminum heads on a 318 stroked out to 349 cu in. Is this possible or should I just go ith a 360 bored .030 over with some eddy heads?
They will fit on a standard bore, whether or not they would provide a benefit depends on the application. Some people notch the cylinder bore to aid in air flow, which is what you might have heard, but it is not necessary.
I don't know how true it is, but I've heard the big valves on a 318 will cost you low end power. Maybe somebody could add to this.
The chambers in the 340/360 head are larger than the chambers in a 318 head. So when you put a 340/360 head with 2.02 valves on a 318 you loose compression and low end power. Also the 340/360 head has bigger ports so when used on a 318 the intake velocity is lower which also impacts low end power.
The easiest, most straight forward and least expensive thing to do is build a 360 vs stroking a 318. Even if you already have the 318 and need to purchase a 360 block it will still be less expensive.
You could go and read the Bowl Blending artical further down on the page and this will help explain the use of larger and smaller valves a bit better and why they aren't needed on small engines, if you need to know more IM me and I'll explain in detail so you won't get it wrong.
im running 2.02 J-heads milled .050 (9.7:1 cr - 56cc chambers) on my .030 318 with a .480 lift cam revved up to about 6,000rpm and they haven't met the cylinder walls.
I've heard they can cost a little on the low end, but with my 3.91s and 3,800flash rpm dynamic converter, i don't think i've come to see a soggy bottom end :)
I think that I am going to stick with running the stock 318 and then put a 4" stroker crank in the 1971 360 that I have sitting in the garage. I also have one J head off from the 360 if anyone is interested. I only have 1, the other one accidently got junked (went to the crushers in the back of a VW) when my Dad was cleaning out his garage. I should have kept the head with the engine. Just PM me if interested in the one I have.
