pishta
I know I'm right....
Late 86 LA "4343475" castings, perfect guides, smog holes filled, light home port in the intake ports and guide shaped. Fresh Serdi 3 angle 2.02 valve seat cut, stock hardened exhaust seats. Heads were cleaned so there is no paint and slight surface rust wipes off. Comes with 8 2.02 intake valves, 7 fresh ground exhaust valves (one was bad), 16 340 springs. Also in the deal is full set of the old 360 1.88/1.60 truck valves (7 HD 2 groove exhaust valves need grinding) 16 360 springs, 8 with dampers, 8 rotator retainers, 16 360 locks, 1 shaft and 8 hydro rockers. . Youll need retainers, Locks are cheap and an EX valve is 9 bucks for a complete set of heads. Ill run these if I dont sell them. So. Cal P/U realistically, shipping would not be economical but figure around $50 a piece if you really need them. $225 obo. In 92780, Tustin, CA. Can bring to Spring Fling, Sat 7AM-11AM parking lot.
New Edelbrock Retainers in pic are for an Olds 350/455, got them in a package deal, wrong stem size but you can have them anyway to flip.
