2) 71 340 engines for sale
340plot
the bushy bush
va
Rating - 95.8%
23   1   0
I HAVE 2 340 ENGINES FOR SALE.
1) IS A 340 WITH BUILD DATE 6/9/71 it is still a steel crank engine, with all parts minus the pistons and rods. it has been cleaned, checked for cracks. still standard bore. also was line honed. crank was polished and is standard. this engine is ready for assembly once you get pistons/rods. had fresh rebuilt 202 j-heads with new valves , springs, and retainers
900.00
2) also a 71 engine and steel crank it is 0.30 over trw pistons. crank and bores have light flash rust on them. has 202 j-heads that need to be redone. also have everything minus the timing cover for this one. 600.00
both have the stock correct intake manifolds
both are located 30 minutes from martinsville international speedway in va
one 340 is sold. (one with rebuilt heads, and magnafluxed and cleaned).
other is still available
