[SOLD] 2 carburetor linkage clips
There are only about 6-8 different kinds and sizes so...
No part number on the carb, and no clip type or application described isn't helping your cause any. :D
It's like only saying you need a tire.
If you are talking about the kind that have a double hole in the top where the choke rod fits and then clips to the choke shaft, the last time I was in O'Reilly they had different sizes blister packed over in the HELP section.
You have to be careful on what size they are.
I picked up an assortment pack for our trans linkages, they have larger holes and shafts. I didn't see any small ones that would fit the choke pull-off in there.... they didn't have any other similar clip packages with those either. Hopefully it's just the stores near me and his will have the right size...
