2 to a 4 --318
AZ340
Active Member
Phoenix Arizona
Is this an easy swap, do i have to buy extra linkinage for the throttle or kick down Iam using an eddy 650 . Iam buying it from summit, is there any thing to get for this change ? I really dont want to oboma rig it.
Ha ha ha, LOL I hear ya.
Lets see, the basics are the intake and carb. From there, the gaskets. Edelbrock sells a plate for use under the carb for there performer intake to use a squarebore carb. IDK if this is needed or not.
After that, the linkage is the issue. What I did was use a Lokar set up. Throttle cable and tranny kick down cables. This made it all alot simpler than searching for OE equipment. While the OE euipment may be available, I'm not sure if it is, but, I do like the flexabilty of the line and it's looks.
For the lokar kit, you'll need part numbers;
SRK- 4000, Cable bracket & springs
TC-1000HT, Throttle cable
KDP-2904HT, 904 kickdown cable
Click below;
http://www.forabodiesonly.com/mopar/showpost.php?p=91646&postcount=80
http://www.forabodiesonly.com/mopar/showpost.php?p=91931&postcount=81
