[SOLD] 22" Radiator w/Shroud 3574636
goldduster318
Overzealous Car Modifier
Lake Orion, MI
For Sale:
~1972 A-body 22" Radiator with matching fan shroud for small block '70-up, PN 3574636.
I just removed it from my car this summer when I installed a higher performance engine. This radiator was able to keep my low compression 360 cool and did not leak. The shroud was cracked but was epoxied back together with industrial strength epoxy. The crack was on the lower section of the shroud, and is not visible once installed. Has automatic trans cooler previsions, but I had them plugged off.
$150+ Shipping.
I also have a matching thermostatic clutch fan and a catch can from a 73-76 A-body if someone is interested in these as well.
