so, how did your conversion come out. I'm interested, but I want to hear the pros and cons, before I undertake such an ambitious mod.
I have ran it as a race only drag car in the slant six. org race series for the past couple of years. I am currently in the process of remaking the car into one that is still race capable, but one that I can drive to the track, cross country included.
The MS ECU has been without issue. The ability to data log and adjust a/f ratios and or ignition timing with a few keystrokes on a lap top is a huge aid at the track.
I am using a locked Lean Burn distributor as a ignition timing source in place of a crank position sensor and a MSD box / MSD coil as a spark source.
The MS3 Pro has built in: rev limiters, launch controls via either fuel or spark cut, that integrate easily with either a trans brake or line locks, electric radiator fan controls, and more.
The downside is if you are doing your own install, you need to be competent in routing and running the wiring harness. There is a writing harness supplied, but the installer has to route it to each injector, throttle position sensor, air temp sensor, IAC, MAP, CLT, fuel pump, power, ground and more if you are running launch control or other options. A bad install/wire routing is not fixable with software. My install has been good, but I can see where the level of detail required is not for everyone and those folks would be better off with TB units.
