Wedgy
Hi together,
I am going to rebuild a 273.
I bought the engine from a Friend. He said that the engine has no power and must be compleatly rebuild.
After I had removed the heads I found some nice domed piston.
The numbers are L2222N.
Volume is -1.35cc.
In the next step I removed the camshaft.
Isky E-4 x88M 3901
I checked the lift and the intake centerline.
Lift is 0.418" on all tappets.
Intake centerline was 104,5°. I will still run the 1.78" intake valves, so I am thinking 109° to 110° would be better.
Could the intake centerline be the reason for the poor performace???
I am having a second camshaft from Edelbrock. It is a 2177.
What are your opinion, timing the E-4 right or go with the 2177 ?
Regard from Hamburg
Martin
Volume is -1.35cc.
Isky E-4 x88M 3901
Regard from Hamburg
Martin
