[FOR SALE] 3.79 Forged Stroker Rods (NEW)
go-fish
SCAT Engine Components 2-350-6125-2100A Scat Pro Sport H-Beam Connecting Rods | Summit Racing
$400 obo
6.125, 2.100 x .927 pin
I bought these for a 3.79" crank build. Plans were to use a Molnar crankshaft. Molnar also has a 4.00" crank that these would work with (2.100 journals).
Diamond has the correct 340/360 piston for this piston pin (.927)
These are NOT Chrysler spec rods. These are "Chevy" spec rods (6.125) that can be used with certain aftermarket Chrysler crankshafts (Molnar) and even certain shelf pistons from suppliers like Molnar and Diamond. No need for custom pistons! I list links to pistons and crank shafts below. This is just part of a 3.79 or 4.00 stroker rotating assembly so save by piecing it together.
They retail for $695 so you're saving $$$. I will ship these for a flat rate of $25 to the lower 48. I will accept cash, check, money order, cashier's check, Venmo, Zelle
These are power adder chevy pistons that will work with these rods, 3.79 crank, and a 4.030 bore (360/396).
11420 Diamond Pistons Chevy 350 Forged 23° Dish 4.030 Bore
Tell your Chevy friends. Apparently these are 350 SBC
rods and would work for those other guys too.
