[FOR SALE] 3:91 complete third member 489 case
rrvolare
19Swinger69
Michigan
Rating - 66.7%
2   1   0
700.00 ( suggest pick up only )...
Nothing wrong with assembly updated gears and internals .. removed from my vehicle to install 742 case 3:91
Any reason you went with the 742 case? i was under the inpression the 489's were stronger/better?
742 is better than 489 which is better than 741.
Pinion diameter I believe where the bearing yoke bearing sits.
If I am wrong- dont shoot the messenger!
489 strongest pinion. But stock cone style suregrip
742 came stock with clutch type sure grip. But smaller pinion shaft
Not enough difference between 89/42 case to spend the money to make a swap to same gear ratio.
Both have about the same strength to last in a race car, neither will get hurt in a typical street ride.
Although the 489 is a 1 7/8 pinion and the 742 is 1 3/4. The 1 3/4 pinion in the 742 has a larger inner pinion bearing for better support.
