TylerW
Hey guys...quick question:
I'm working on an '83 slant that we did an HEI conversion on. The cap is oriented differently between the LB and non-LB distributors(I think) so I had to start over at TDC and drop in the dist there.
However....there are 3 marks on that balancer each 1/3 of the way around the balancer. The only difference is one mark is longer than the other two and both valves appear to be closed at that point. I say appear because this is a hydraulic engine and there's no slack in the rockers.
Is THIS the TDC mark?
That has to be something to do with the Lean Burn...
Thanks,
Tyler
Thanks,
Tyler
