3 on the tree conversion
bradfloyd
New Member
Indiana
I have a 72 valiant that I am tired of fighting the column linkage slop on and don’t even want to think about taking the column apart to rebuild it. I would like to keep my hands clean when I drive it from now on. I know you can convert to floor shift on these column shifters. Anyone know any good quality options for floor conversion kits?
Check out Summit. They have a few listed.
I just recently had the same issue. I have a 68 Barracuda with a slant 6 and 3 speed manual xmission which had 3 on the tree but I was missing the linkage so I decided to go with a floor shifter. I bought the Hurst/Indy shifter from Summit, nothing fit but I was able to make it work by modifying the hardware that was provided. I had to drill and cut the bracket they provided and it barely fit. The hole in the floor was already there from the previous owner. I could send pictures if needed.
