jose65cuda
Will a 3 speed floor shift tranny from a 70 duster work on a 66 dart 3 speed column shift.
What do you mean by top loader?is it a top loader ?
I will let you know I will be pulling it out of the duster tomorrowis there a plate bolted on the top of the transmission to get into it to service it or is it like a 4 speed with the access on the side
66 Dart slant 6 bought it with out a tranny so don't know what it had originally. I am parting a 70 duster with floor shift slant 6 I was hoping I could use the tranny and retain column shift. If not I will be looking for a top loader tranny.If original to a floor shift Duster, it will be a side loading A230.
I bet the '66 has a top loader.
If anyone has done this swap before & retained the column shift, I have not heard about it before?
The floor shift car is an A230
The 66 has either an A903 or 748. Neither of those transmissions has any provision for a floor shift.
The good news is, your A230 will plug right into the older Bell Housing and take the same trans mount and drive shaft as the 66
You can make it work with some fabrication, but you're probably better off adapting the floor shifter from your parts carSo will the 66 column linkage work on the 70 duster tranny? Bell housing and clutch is still behind the slant 6 on my 66.
That might be the way to go ThanksYou can make it work with some fabrication, but you're probably better off adapting the floor shifter from your parts car
Well,if you need a 66 top loader 3 spd transmission I have a few but I'm in NY.66 Dart slant 6 bought it with out a tranny so don't know what it had originally. I am parting a 70 duster with floor shift slant 6 I was hoping I could use the tranny and retain column shift. If not I will be looking for a top loader tranny.
Parts get delivered by truck every day...valiantwagonguy
Thanks for the offer that's a bit kinda to far if you were closer I would take you up on the offer.
The A230 is a far superior transmission, and it is fully synchronized, unlike the older stuff..
To retain the column shifter;
The shift levers IIRC are slightly further apart on the 230, and perhaps a tad lower. So your shiftrods MAY not be the right lengths. The lever ratios will also be slightly different, so you will have to sync them up. This is just cut and paste work, you'll be done in a couple of hours.
