30 spline Dana 60 axles and housing ends
jrlegacy23
68 Barracuda
Laurens, NY
I have a set of Dana 60 axles with green bearings and 3" screw in studs installed. I also have a set of moser axle ends to go with it.
The axles are for 54.625" wide Dana 60 with a stock pinion offset, from wheel mounting surface to wheel mounting surface. As per Doctordiff, these axles have enough splines to be cut down, on a chopsaw, to around a 50" wide rear and will work with a 8 3/4 rear also. Everything is new and never installed on anything. I bought the axles from doctordiff for $325 plus shipping and the housing ends from summit for $89.
Axles sold, Moser housing end still available $60 shipped to lower 48 states
I am located near Cooperstown, NY.
PM me here or email me jrlegacy 23 @ yahoo .com (without spaces)
