30x12x15 on 68 Cuda ?
DonnieLawson
68 Barracuda
Middletown Ohio
Found a good deal on some 30x12x15 rear tires for my 68 Cuda that is being mini tubbed , If I move the rear back 1" , will these tires fit in the wheel well ?
Do you guys move the rear back 1 " or 1 1/4 " ?
Im gonna have the Dana cut after I get the rims and tires .
Just really dont want this deal to pass on the tires , but dont want to buy what I cant use .
What size are you guys running ? And will these fit ?
Thanks guys ..
I have a 65 cuda, mini tubbed w/ 28x12x15 MT's, I cut 1 1/4" out of the front wheel well for clearance, have plenty room to move up to a 30" tire on the next set. If you move an 1" rearward you should be good to go. Some one with a 68 would show more light on the issue. Hope this helps.
Roger
I'm running 29x12.5x15 on my 67 with the diff pushed back an 1", I would be hard pressed to stuff 30" not enough room.
How much wider could you go ?
I wanting the biggest that will go in the wheelwell .
I heard someone had a 31X13X15 in one . That seems way big to me , But it would look cool.......
