318 1/8 time improvement
Mopar Racers Forum
  1. Slantsix64
    Slantsix64 Well-Known Member
    3,017
    1232
    May 11, 2014
    SGV
    Local Time:
    1:10 AM
    Hey guys went to the track yesterday, wanted you guys to see where I can improve, this is a stock bottom end 1989 roller 318 engine with a rv camshaft regrind 650 Avs and ld4b intake. In my 67 barracuda. I know I can be a bit quicker using the same camshaft and adding 1.6 ratio rocker arm along with some magnum heads with an rpm air gap. But I know off the line I get a stupid bog sometimes, and my traction is not so great. Running one cheater slick lol
    More info 1967 barracuda notchback 904 transmisson 8 3/4 3.91 gears 9:5 compression Here's the full camshaft specs , 260Intake/264exhaust duration .410/425 lift duration( with 1.5 rockers) @.050 203/208 lobe center 108/112
    Grind Number #1006
    • Like Like x 1
    • 318willrun
      318willrun Utube channel 318willrun
      16,921
      18971
      Sep 13, 2013
      I'm here
      Local Time:
      1:10 AM
      Post your ET slip. What converter, transmission, gears, and what's the vehicle? What are the specs of the cam. Also, tire size. You bogged out of the hole, so I assume you didn't spin a lot.
    • oldkimmer
      oldkimmer FABO Gold Member FABO Gold Member
      19,049
      6301
      Nov 11, 2006
      Kindersley, Saskatchewan,
      Local Time:
      1:10 AM
      How much does it weigh? What were ur shift points? Kim
    • Slantsix64
      3,017
      1232
      May 11, 2014
      SGV
      Local Time:
      1:10 AM
      Yeah will this damn carb has been pissing me off but ya these is a little bog it comes and goes.
      It’s a 1967 barracuda 318 a904 9:5 compression roller camshaft 8 3/4 with 3.91s rear tires 255 60 15 let me look up the specs real quick!
    • Slantsix64
      3,017
      1232
      May 11, 2014
      SGV
      Local Time:
      1:10 AM
      As you can see I’m running the 1.5 ratio rockers vs the 1.6 that would give me little more lift
    • 318willrun
      16,921
      18971
      Sep 13, 2013
      I'm here
      Local Time:
      1:10 AM
      the ET slip looks "steady" for the time/mph. But, I think it's "soft" for the combo.
      • What altitude is your track?
      • What is your total timing?
      • Did you verify the throttle is coming wide open?
      • Agree Agree x 1
      • Slantsix64
        3,017
        1232
        May 11, 2014
        SGV
        Local Time:
        1:10 AM
        Yeah well that was with no manual shifting so the car was shifting at 5k but when I manually shift it she can hit 6k before she goes flat. The transmisson has a transgo shift kit and stock converter. I believe I’m at total 32 but I would have to check I know for sure I have 18 mechanical that’s how I set the plate. With the light spring.
        370 track elevation, and yes I verified I’m getting wot
      • Slantsix64
        3,017
        1232
        May 11, 2014
        SGV
        Local Time:
        1:10 AM
        Kim, I actually never weighed it, but pretty much everything was still on The car, trunk had my tools and a spare tire, and a old 1989s tape player lol when I tired manual shifting I would shift at 6k but me time actually cam out slower because of that little bog
      • Slantsix64
        3,017
        1232
        May 11, 2014
        SGV
        Local Time:
        1:10 AM
        Do you thinking adding some tracking bars would help with the 60ft?
        • Like Like x 1
        • flyfish
          flyfish C8H18+N2O = :-D
          2,284
          868
          Apr 16, 2007
          Indy
          Local Time:
          2:10 AM
          No, traction bars and old Mopars don't mix well. A cheap alternative is a pinion snubber and some drag shocks.
          Good news is (at least according to Wallace) your ET/MPH line up.
          60' to 1/4 Mile Calculator - Wallace Racing
        • RustyRatRod
          RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
          71,491
          46624
          Jun 7, 2010
          Georgia
          Local Time:
          2:10 AM
          Maybe add the other cheater slick?
          • Agree Agree x 2
          • Thanks! Thanks! x 1
          • oldkimmer
            19,049
            6301
            Nov 11, 2006
            Local Time:
            1:10 AM
            Yup, a pair in anything is better. Kim
            • Agree Agree x 1
            • 318willrun
              16,921
              18971
              Sep 13, 2013
              I'm here
              Local Time:
              1:10 AM
              If you have stock leafs and an open rear end, then YES !!! Stay away from pinion snubbers with open rear ends! And get the other cheater slick... lol
              • Like Like x 1
              • RustyRatRod
                71,491
                46624
                Jun 7, 2010
                Georgia
                Local Time:
                2:10 AM
                Especially titties. You saw where that was goin I'm sure.
                • Like Like x 2
                • 318willrun
                  16,921
                  18971
                  Sep 13, 2013
                  I'm here
                  Local Time:
                  1:10 AM
                  Just because it will "hit" an RPM, don't mean it will run the best ET there. You'll have to play with shift points. Maybe next time try 5300 and see how it responds. And play from there... Also, play with timing. It may like 34* or 36*, who knows till you try it.
                • Slantsix64
                  3,017
                  1232
                  May 11, 2014
                  SGV
                  Local Time:
                  1:10 AM
                  Lol damn back order. But ya will do!
                • Slantsix64
                  3,017
                  1232
                  May 11, 2014
                  SGV
                  Local Time:
                  1:10 AM
                  Wallace says 1/4 mile 15.68
                • Slantsix64
                  3,017
                  1232
                  May 11, 2014
                  SGV
                  Local Time:
                  1:10 AM
                  Okay will do!
                • oldkimmer
                  19,049
                  6301
                  Nov 11, 2006
                  Local Time:
                  1:10 AM
                  Yupper I did. I knew u would answer back with that answer. Lol. Kim
                • Slantsix64
                  3,017
                  1232
                  May 11, 2014
                  SGV
                  Local Time:
                  1:10 AM
                  What do you think about adding the magnum head? With that 1.6 rocker ratio I should get more lift and bigger valves are always good! Lol
                • oldkimmer
                  19,049
                  6301
                  Nov 11, 2006
                  Local Time:
                  1:10 AM
                  Tune what u got first. Then u can upgrade when ur car is all sorted out. A good running motor makes a big difference. Kim
                  • Agree Agree x 2
                  • Slantsix64
                    3,017
                    1232
                    May 11, 2014
                    SGV
                    Local Time:
                    1:10 AM
                    10-4!
                  • 318willrun
                    16,921
                    18971
                    Sep 13, 2013
                    I'm here
                    Local Time:
                    1:10 AM
                    It would be good. But, I always advise not to start unbolting and bolting a bunch of stuff - sort of throw things at a car without FIRST fixing what you have. Fix the bog, fix the traction, time it, tune it and play with shift points. You might get a 8.9 at 76 or something... just saying... then make your change.
                  • flyfish
                    2,284
                    868
                    Apr 16, 2007
                    Indy
                    Local Time:
                    2:10 AM
                    Going from a 1.5 to a 1.6 rocker on such a mild combo is a waste of money, probably no gain...just a lighter wallet.
                    • Agree Agree x 4
                    • AJ/FormS
                      AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
                      20,743
                      8135
                      Jan 19, 2014
                      South-Central Manitoba,Canada, 900ftelevation
                      Local Time:
                      1:10 AM
                      My 68 Barracuda 367/A833/8.75 was 3650 on race day, me in it. Probably 3450 on it's own with about a half a tankful.( aluminum heads and intake, P/S, P/B, front sway bar,friggen heavy HD shocks, fold-down rear seat, full length 3in/3out duals,alloy wheels, no spare or jack.)
