1. Dartn440
    Dartn440 FABO Gold Member FABO Gold Member
    3,484
    1106
    Jun 2, 2013
    Southern Pines, NC
    Local Time:
    4:43 AM
    I have a 1966 steel crank 318 I picked up because I needed the 360 heads it was wearing. Guy I got it from told me he thought it was “built pretty good.” He pulled it for a bigger motor in his B body.
    I have torn down my fair share of motors that we’re “running when pulled” and most must have been powering submarines because they looked like shit when you started to tear them down.
    I’ll be sending everything off to the machine shop for tolerance checks and a good once over. Cylinders are clean at .030 with a flat top down in the hole a bit so I am considering upping the compression to at least 9.5:1. I have set of fully machined 360 heads with bigger valves ready to go.
    The rotating assembly had meat taken out of the underside of the pistons, crank, rods for balancing. All bearing surfaces looked great, mains were standard, rods were standard or .0001. Not sure I can get the latter anymore so those may have to be turned.
    Intake I have on hand is Performer RPM 318/360. I am going this week to pick up and LD4B and can also get ahold of a Performer Air Gap.
    Whattya think?
  2. krazykuda
    krazykuda Well-Known Member FABO Gold Member How-To Section Editor
    59,046
    24762
    Aug 20, 2007
    Orland Park, IL
    Local Time:
    3:43 AM
    If it's a 66 318, I would make sure that it's not a poly... 66 was the last year of the poly, 67 was the first year of the LA 318.... They are different...
    • Agree Agree x 1
    • Dartn440
      3,484
      1106
      Jun 2, 2013
      Southern Pines, NC
      Local Time:
      4:43 AM
      I’ll go back and look at the block....could have sworn I saw 66. But then again, we were cooking a block in the cleaner, there was welding, cutting, and energy drinks involved....lol
    • krazykuda
      59,046
      24762
      Aug 20, 2007
      Orland Park, IL
      Local Time:
      3:43 AM
      If the date is after June of 66, it's most like a first edition of the 67 318 LA.... They launch the new models in June/July....
      If it's like a January cast date block, then it may be a poly.... It's easy to tell a poly by the bottom of the valve cover is uniquely shaped...
      • Agree Agree x 1
      • Dartn440
        3,484
        1106
        Jun 2, 2013
        Southern Pines, NC
        Local Time:
        4:43 AM
        Front of the block was stamped C318 and I pulled 360 heads off it when I brought it home. Definitely not a poly...might be an early cast as you mention
      • 66fs
        66fs FABO Gold Member FABO Gold Member
        5,712
        2251
        Sep 9, 2009
        Greenwood, South Carolina
        Local Time:
        4:43 AM
        Sounds like a great start.
        • Like Like x 1
        • Agree Agree x 1
        • 66fs
          5,712
          2251
          Sep 9, 2009
          Local Time:
          4:43 AM
          The LD4B should be the smaller 273 or 318 ports.
          • Thanks! Thanks! x 1
          • Agree Agree x 1
          • JDMopar
            JDMopar Well-Known Member
            4,041
            2997
            Jan 19, 2012
            Candler, NC/Myrtle Beach, SC
            Local Time:
            4:43 AM
            If you're using the 340/360 heads, use the air gap. Using those heads, I'd probably spring for a set of KB-167's to keep the compression from being 4.9-1 ! :eek:
            • Like Like x 1
            • Agree Agree x 1
            • Dartn440
              3,484
              1106
              Jun 2, 2013
              Southern Pines, NC
              Local Time:
              4:43 AM
              I was not planning on swapping pistons as my solution. Trying to keep it as budget as I can. The pistons in it are balanced to the assembly and look practically new. Since it came with 360 heads I am going to assume that was taken into consideration when it was originally put together. All going to the machine shop together to get an exact read on what was already done to block surface and previous 360 heads.
              No dogs here....
            • krazykuda
              59,046
              24762
              Aug 20, 2007
              Orland Park, IL
              Local Time:
              3:43 AM
              A stock 72 318 with 360 heads will get 7.5 compression, an early 318 with 360 heads will be a little higher...
              If you want to bump the compression into the 8's, get a set of original 66 - 67 273/318 heads with the smaller combustion chambers... Just port the heads and install larger intake and exhaust valves...
              • Like Like x 1
              • Dartn440
                3,484
                1106
                Jun 2, 2013
                Southern Pines, NC
                Local Time:
                4:43 AM
                And after nearly a year the machine shop got to my 71 400.......
              • Dartn440
                3,484
                1106
                Jun 2, 2013
                Southern Pines, NC
                Local Time:
                4:43 AM
                8-26-66
              • replicaracer43
                replicaracer43 Grumpy Old Man
                4,921
                4269
                Oct 10, 2008
                Local Time:
                3:43 AM
                Your in NC correct?
              • Dartn440
                3,484
                1106
                Jun 2, 2013
                Southern Pines, NC
                Local Time:
                4:43 AM
                Yes sir.
              • toolmanmike
                toolmanmike FABO MODERATOR Staff Member FABO Gold Member
                58,902
                46048
                Jan 18, 2006
                Iowa
                Local Time:
                3:43 AM
                • Like Like x 1
                • replicaracer43
                  4,921
                  4269
                  Oct 10, 2008
                  Local Time:
                  3:43 AM
                  Sending a PM
                • Dartn440
                  3,484
                  1106
                  Jun 2, 2013
                  Southern Pines, NC
                  Local Time:
                  4:43 AM
                  Could have sworn I saw 66 when I was working on it. Guy told me he pulled it out of a 67 Belvedere.
