Lil Demon
New to the forum and already have questions. I just bought a 71 Demon with no engine/trans. I currently have a 230 hp 318 2bbl sitting in my 70 'Cuda with the 904 or is it 727 (?) which I plan to swap into the Demon. I plan on installing a Edelbrock air-gap intake, Holley or Demon 4bbl, and headers. From what I have read this motor is supposed to have 9.2:1 compression. Is this true? How can I tell. If so what is the best all around cam (268 or purple+) or others with maybe a small stall converter. The car has a 3.23 rear gear. Just want a good torquey rev happy little setup while I eventulally build up a 340 motor I have. Really just want something fun/cheap to drive while I finish other projects. I plan on using the intake/carb/header setup for the eventual 340.
