318 to 360 LA Swap. Trans mounting Problem.
Transmission and Drivetrain Tech
  1. jtn2655
    jtn2655 New Member
    2
    0
    Aug 24, 2020
    Georgia
    Local Time:
    2:46 AM
    Hey all you wizards,
    I recently rebuilt a ‘77 360 LA. While putting into my ‘72 Dart (Original 318) I’ve run into nothing but problems. My most recent is not being able to match up the bottom 2 bolts from the block to the original 904 trans in the car. There is about a 1/2 inch gap in between them. I’ve jacked the engine up and jacked the trans up and every combination of the 2. Not to mention the B&M flex plate (part no.BMM-10236) won’t get closer than about an 1/2 away from converter. Anyone with ideas help me please.
  2. Commando66
    Commando66 She's a beaut Clark!
    1,998
    465
    Dec 2, 2007
    Gig Harbor, WA
    Local Time:
    11:46 PM
    Is the torque convertor seated all the way? Three "clunks" while rotating into the pump?
  3. eekvonzipper
    eekvonzipper My Member is Legendary! FABO Gold Member
    497
    393
    Apr 18, 2020
    Cadet, Missouri
    Local Time:
    1:46 AM
    Yeah, You Have to Spin and Push the Converter until it Seats... Did You Do That?
  4. SGBARRACUDA
    SGBARRACUDA ROY FABO Gold Member
    19,545
    7954
    Dec 7, 2006
    PLANT CITY FL. and PERRY GA.
    Local Time:
    2:46 AM
    Good way to break the ears off the front pump gear. If you forced it together they are probably already broke.
  5. CudaFactHackJob
    CudaFactHackJob FABO Gold Member FABO Gold Member
    1,628
    616
    Mar 17, 2016
    Hemet, Ca.
    Local Time:
    1:46 AM
    Oh hellno, none of that turn, clunk, clunkity turn stuff...place a straightedge across the front of the trans. Measure back to the converter pad, with the converter turned so that the pad you are measuring to is either to your right or left, not top or bottom. Then measure from the back of the block to the back of the flexplate. The trans measurement has to be MORE; by like 1/8"
  6. Heywodja
    Heywodja The Heartbeat Stops Here FABO Gold Member
    682
    321
    Aug 16, 2014
    Texas
    Local Time:
    1:46 AM
    The engine or transmission could also be slightly rotated off axis which prevents the two dowel pins on the transmission from engaging the back of the block properly.
    • Agree Agree x 1
    • moparzepjr
      moparzepjr New Member
      2
      0
      Jul 3, 2015
      stahlstown pa.
      Local Time:
      2:46 AM
      make sure you dont have a dowel pin from the 318 still stuk in the trans bell
    • CudaFactHackJob
      1,628
      616
      Mar 17, 2016
      Hemet, Ca.
      Local Time:
      1:46 AM
      Cut some bolts off and grind them to a point and screw them into the block to guide the trans on. About 2" long.
    • moparmarks
      moparmarks zippindippintie FABO Gold Member
      1,567
      852
      Oct 5, 2014
      Western Colorado
      Local Time:
      12:46 AM
      I do this with 4-speeds. Works great.
    • moparmarks
      1,567
      852
      Oct 5, 2014
      Western Colorado
      Local Time:
      12:46 AM
      Nothing but crickets from the OP.
    • SGBARRACUDA
      19,545
      7954
      Dec 7, 2006
      Local Time:
      2:46 AM
      That is a good idea. Ive done that for installing front pumps on transmission when i rebuild them.
