340 Build Final Combo. What Do You Think?
Small Block Mopar Engine
  1. Road Grabber
    Road Grabber Member
    21
    0
    Jun 30, 2020
    Cape Vincent New York
    Local Time:
    8:19 AM
    I don't know anyone else's experience but I used an aluminum flywheel one time and hated it. There was no inertia for letting off the clutch and I didn't like it for the street at all. I found myself burning the clutch more to get going and hole shots was much different. It was a 440 with plenty of power. Starting off in gear was terrible. Just a thought. I am sure the others have thoughts to share. Good luck. Great motor!
  2. mderoy340
    mderoy340 Well-Known Member
    2,358
    1138
    Aug 2, 2012
    Melbourne FL
    Local Time:
    8:19 AM
    Very similar to my combo except trans, 110 is realistic.
  3. yellow rose
    yellow rose Walking the crooked mile
    22,904
    18891
    Jun 19, 2015
    Living on the razors edge
    Local Time:
    5:19 AM
    I never use anything but aluminum. If you have a 2.20 first gear (Chrysler never made a box with that first gear ratio but IIRC the M21 or M22 Muncie had something like that worthless first gear so I’m using that as an example) and a 3.08 axle ratio it may not like an aluminum flywheel.
    And if the car is 4500 ponds and geared like that it would suck.
  4. RAMM
    RAMM Well-Known Member
    1,767
    1634
    Nov 22, 2010
    Ontario, Canada
    Local Time:
    8:19 AM
    Empty your inbox please. J.Rob
  5. ir3333
    ir3333 Well-Known Member
    4,633
    1192
    Jun 1, 2008
    ontario,canada
    Local Time:
    7:19 AM
    i'm not convinced that cam is a good match for the J heads.For a daily driver i'd opt for the rpm and ditch the air gap.Drop down to 2 1/2" exhaust and 1 5/8" headers.No H or X and 650 Thunder Edelbrock
    ...is 10:1 estimated?
  6. ValiantKindOfGuy
    ValiantKindOfGuy Well-Known Member
    254
    53
    Aug 14, 2019
    Plympton Mass
    Local Time:
    8:19 AM
    You almost had me for a second... I almost thought you were serious until I saw no x or h :rofl:
    I’m surprised you didn’t go with a thermoquad lol.
    No it’s calculated along with my dynamic.
    • Agree Agree x 1
    • ValiantKindOfGuy
      254
      53
      Aug 14, 2019
      Plympton Mass
      Local Time:
      8:19 AM
      Getting on it now sorry.
    • ValiantKindOfGuy
      254
      53
      Aug 14, 2019
      Plympton Mass
      Local Time:
      8:19 AM
      That’s what I was hoping. What’s your combo?
    • Wyrmrider
      Wyrmrider FABO Gold Member FABO Gold Member
      3,466
      1658
      Sep 5, 2016
      los angeles
      Local Time:
      5:19 AM
      I took it the way RRR posted
      • Like Like x 1
      • Agree Agree x 1
      • Cruze426
        Cruze426 FABO Gold Member FABO Gold Member
        143
        44
        Mar 11, 2019
        Illinois
        Local Time:
        7:19 AM
        I also took the way that it was posted. No way that you would ever have enough valve clearance. My understanding.
        Sometimes-----------------------------------
      • ValiantKindOfGuy
        254
        53
        Aug 14, 2019
        Plympton Mass
        Local Time:
        8:19 AM
        So you took it as I did?
      • Cruze426
        143
        44
        Mar 11, 2019
        Illinois
        Local Time:
        7:19 AM
        YES
        • Agree Agree x 1
        • ValiantKindOfGuy
          254
          53
          Aug 14, 2019
          Plympton Mass
          Local Time:
          8:19 AM
          Gotcha. I have no problem with rusty. At all. In all honestly I overreacted a little and I’m over it.
        • ir3333
          4,633
          1192
          Jun 1, 2008
          ontario,canada
          Local Time:
          7:19 AM
          what do your heads flow?
        • ValiantKindOfGuy
          254
          53
          Aug 14, 2019
          Plympton Mass
          Local Time:
          8:19 AM
          No idea. Didn’t do the port work so let’s say better than a stock port or worse than a stock port.
        • ir3333
          4,633
          1192
          Jun 1, 2008
          ontario,canada
          Local Time:
          7:19 AM
          OK..stock heads stall out at about .480 lift and that's why i questioned the cam. I thought i read daily driver and your other choices seem to favour a quarter mile piece.
        • ValiantKindOfGuy
          254
          53
          Aug 14, 2019
          Plympton Mass
          Local Time:
          8:19 AM
          I’m really don’t mind suffering a bit to be as max effort as I can when it comes to a daily. In my opinion a bigger cam doesn’t change drivability it just changes the rpm range at which you do so. From what I’ve seen from the stock port heads, you are absolutely right. But I’m hoping with this port work it will allow the flow to average in higher lifts (not necessarily gain) so I’d be okay. The cam is being run because it’s what I have even though I need better heads. (Would really like a set of LAX heads)
        • RustyRatRod
          RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
          61,610
          33561
          Jun 7, 2010
          Georgia
          Local Time:
          8:19 AM
          Here is what I MEANT to say. My bad. I'm old and I was tired.
          "I don't think that combo has a snowball's chance in hell of piston to valve INTERFERENCE"
          But again, nothing smartass was EVER meant or implied.
          • Agree Agree x 1
          • ValiantKindOfGuy
            254
            53
            Aug 14, 2019
            Plympton Mass
            Local Time:
            8:19 AM
            It’s over with. No hard feelings just let it go.
          • Nat
            Nat Well-Known Member
            264
            146
            Jun 11, 2019
            Netherland
            Local Time:
            8:19 AM
            you should be able to do that , i had a 340 similar build but automatic ran a best of 13.1 at 106 mph , but i'm not much of a drag racer and traction was a problem . you should do better
          • ValiantKindOfGuy
            254
            53
            Aug 14, 2019
            Plympton Mass
            Local Time:
            8:19 AM
            It should be around there
            I’m hoping to get the whole car together in the next couple weeks. Hopefully it goes that quick lol.
          • mderoy340
            2,358
            1138
            Aug 2, 2012
            Melbourne FL
            Local Time:
            8:19 AM
            67 Dart - 340 .040 Speed Pro flat tops .020 above 10.3:1, 4bbl 750dp, Airgap, Comp SFT XS274S 236@.050 cam .500 lift, 63cc IMM indy LA X iron heads, TTI headers, low gear set 904/gvod, Turbo Action 10" 3200 converter 4.10, 3200 lbs. Best so far 11.77@113.7
            • Like Like x 2
            • ValiantKindOfGuy
              254
              53
              Aug 14, 2019
              Plympton Mass
              Local Time:
              8:19 AM
              How in the hell could I possibly buy those heads from you? Lol kidding. Kinda. I’ve been looking for a set of IMM LAX heads.
            • mderoy340
              2,358
              1138
              Aug 2, 2012
              Melbourne FL
              Local Time:
              8:19 AM
              They do work good; it would take a pile of cash for me to part with them!
            • ValiantKindOfGuy
              254
              53
              Aug 14, 2019
              Plympton Mass
              Local Time:
              8:19 AM
              I can imagine why haha. They are sweet heads and I would love to get a set. If you guys have a set feel free to pm me lol.
