[FOR SALE] 340 Dart Sport
63SplitWindow
Montgomery County PA
Original 'H' code 340 console auto
Body is very nice and straight. No bondo or rust anywhere. Floors as nice as body.
Black cherry paint is older but shows very well.
Car is all steel except for hood. All factory glass.
Car is back halved with frames tied. Four link with coil overs.
Car is tubbed with 29.5 X 12 X 15 Hoosiers out back.
15 gal fuel cell with Holley electric pump'
Battery relocated to trunk with cutoff out back.
Electric fan with aluminum radiator.
Squeezed 8.75 rear with 4:56 gears, spool and Strange axles.
I have owned this car for 2 years and installed many upgrades.
NEW Painless wire harness for entire car, eliminating troublesome bulkhead connector.
All lights, signals and horn work for street use.
NEW 1 wire 100 amp alternator. NEW gauges with LED lighting.
FRESH rebuild of 727 trans with heavy duty clutches, RMVB, new TCI flex plate, new PTC 4500 converter.
Hurst Quarter Stick shifter
NEW TTI long tube headers. 1 7/8 primaries with 3.5" collectors.
Car looks,runs and sounds great. Can't buy and build this car for this money.
I also have a fresh 360 block, J heads, new rods and pistons and Mopar solid lift cam that could be packaged in the deal
$25k
The internals are all 340. KB forged dome pistons that were cut down to 11:1 compression. 340 six pack rods and forged crank. 360 heads were ported with 2.02 intakes with 1.6 adjustable rockers and port matched to Victor 340 intake
Is the car street legal and do you have a clear title? Nicely done.
Yes. Clear title in hand and current Pa state inspection. I will add that the wipers are currently not working. All lights horn and turn signals (even hood indicators) work as designed.
Looks like my last message got posted without me finishing it. The bottom line here is that I'm not going to jump into this until I'm sure I can commit to being a serious buyer. I hate to be a 'tire kicker' about this but the timing isn't right just now. I won't commit to a car unless I've been there to look at it and inspect it. That won't happen until I can get my court judgement resolved. I'll be sure to let you know if anything changes. Thanks for getting back to me.
