[SOLD] 340 parts
Sedanman
67-9 Valiant specialist
chicago Il
6/16/71 vin#2B306416 std bore 340 bare block & 1.88 915 heads with valves & springs (no rockers or shafts) $425 obo
2 aluminum right angle oil filter adapters with bolt $30 ea
I have a set of 4 bolt main caps for 340. $50
4 windage tray bolts for small block $25
shipping is extra.... I am willing to trade for some things I need like
8 3/4 matched usable rear brake set up for 10" or 11" BBP
67 radio antenna,I have the nut & bezel
a good 70-2 v8 22" radiator & shroud if possible
670 Holley street avenger carb
Still have the 915 heads w/ 1.88 valves,1 filter adapter,4 bolt caps & tray bolts
that is a vary nice signet you have there. i was trying to buy it when the kid you got it from bought it from. when justin said he was going to check out the engine for you, i was more than happy to get a closer look at it. i also have a 67 signet, and i sold justin his about ten years ago. its my favorite mopar across the board. good luck with your build.
Just wanted to say thanks for the great deal on the 340 block its just what I've been looking for, and thanks again Chuck.:burnout:
i have a set of rear 11 x2.5 backing plates with brakes installed <but need changed>id swap for the heads if interested?
They were on a 360 I stripped & have 188/160 valves.
dgoplen,do you have the drums as well? All thats left are the complete heads
i dont have the drums but they are easy to find at local parts house ,i am not sure if these are 2 or 2.5 but i believe the backing plates will work for 2 or 2.5 just make sure the drums are the same.all the bhardwar i sinstalled on these. if interested i can go measure exactly what they are.i am in sw wisconsin zip 53581 . tks scott
Do you still have the windage tray bolts? If so, how much shipped to 78612
