340 thermoquad hard starting
Fuel and Air Systems
  1. dancinwulf
    dancinwulf Well-Known Member
    79
    7
    Apr 8, 2015
    Ketchum Idaho
    Local Time:
    12:23 AM
    My 340 starts immediately once running but is hard to start when cold, is there a choke that can be fitted or is there any tricks I can try.
  2. toolmanmike
    toolmanmike FABO MODERATOR Staff Member FABO Gold Member
    52,760
    38265
    Jan 18, 2006
    Iowa
    Local Time:
    1:23 AM
    It should have a choke that closes when you push the gas pedal to set it when you start it cold.
  3. dancinwulf
    79
    7
    Apr 8, 2015
    Ketchum Idaho
    Local Time:
    12:23 AM
    It does but I don't think it stays closed long enough is there an adjustment
  4. missing linc
    missing linc Loose nut behind the wheel
    1,922
    2868
    Feb 17, 2019
    Southern Alberta Canada
    Local Time:
    12:23 AM
    Pics would help, need to determine the existing setup, whether your carb is oe or aftermarket
  5. dancinwulf
    79
    7
    Apr 8, 2015
    Ketchum Idaho
    Local Time:
    12:23 AM
    Here are the views from both sides
  6. toolmanmike
    52,760
    38265
    Jan 18, 2006
    Iowa
    Local Time:
    1:23 AM
    It has a choke butterfly and some linkage but no chole coil in the intake to close it when cold. You may need to get a Factory service manual to find all the needed parts and adjustments. PS, loading photos directly to the site is quite easy and much more convenient for us.
  7. dancinwulf
    79
    7
    Apr 8, 2015
    Ketchum Idaho
    Local Time:
    12:23 AM
    Not sure how to accomplish that I thought that was what I was doing
  8. toolmanmike
    52,760
    38265
    Jan 18, 2006
    Iowa
    Local Time:
    1:23 AM
    Just a couple keystrokes and I found this. You can see what you are missing. It would be smart for you to check the number on the intake and carb to make sure they are compatible with the choke pieces you will need. If you have a mish mash of parts it will be a lot tougher to come up with the right combination.
    • Agree Agree x 1
    • 70 DUSTER CRATE
      70 DUSTER CRATE Well-Known Member
      487
      190
      Jan 24, 2009
      here
      Local Time:
      2:23 AM
      I like a hand choke cable.
    • lemondana
      lemondana BlackDart
      484
      274
      Dec 7, 2007
      Southeast NE
      Local Time:
      12:23 AM
      I think Quadrajet Parts has an electric choke conversion that bolts onto the manifold like the original one does.
    • RustyRatRod
      RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
      64,401
      37352
      Jun 7, 2010
      Georgia
      Local Time:
      2:23 AM
      • Like Like x 1
      • 66fs
        66fs FABO Gold Member FABO Gold Member
        5,014
        1663
        Sep 9, 2009
        Greenwood, South Carolina
        Local Time:
        2:23 AM
        That should do it. A TQ needs to have the choke close to start cold.
      • toolmanmike
        52,760
        38265
        Jan 18, 2006
        Iowa
        Local Time:
        1:23 AM
        Yep, it's not like a Holley that squirts a couple shot glasses of gas with every stomp on the loud pedal. :lol:
        • Like Like x 1
        • lemondana
          lemondana BlackDart
          484
          274
          Dec 7, 2007
          Southeast NE
          Local Time:
          12:23 AM
          I've been using them for a long time. They haven't worked well, take forever to heat up. You need to use that little resistor thing called the choke control. The power wire plugs into the choke control and the choke control plugs into the choke wire. I'm sure it will work like Chrysler intended then. That Tomco one doesn't have the wire but the factory ones and the Carter ones do. The part number for the choke control is 3755770. The early mechanical TQ chokes that used a gasket below the well cup always seemed to work better for me.
        • lemondana
          lemondana BlackDart
          484
          274
          Dec 7, 2007
          Southeast NE
          Local Time:
          12:23 AM
          Sorry" I meant to quote Rustys post for the above.
        • RustyRatRod
          64,401
          37352
          Jun 7, 2010
          Georgia
          Local Time:
          2:23 AM
          You are correct in that they don't heat up quickly, but not all of them were electric, either. The elarly TQ cars didn't have the electric assist. I was trying to choose the most economic option. Those electric ones are pricey.
        • RustyRatRod
          64,401
          37352
          Jun 7, 2010
          Georgia
          Local Time:
          2:23 AM
          Especially the ones whose choke well is actually open to the exhaust cross over. Those really work well.
        • 66fs
          5,014
          1663
          Sep 9, 2009
          Local Time:
          2:23 AM
          That one is perfect. There was a truck choke that is not electric, I always used the truck one myself. I'll try and look the Chrysler number up later.
        • missing linc
          1,922
          2868
          Feb 17, 2019
          Local Time:
          12:23 AM
          I ran a TQ for years without the choke, from -40 to 90* above, had to pump the thing about 40 times on cold days and feather it for few minutes once she did fire.
        • 66fs
          5,014
          1663
          Sep 9, 2009
          Local Time:
          2:23 AM
          I also ran a TQ for years. Set it up right, it ran like fuel injection from -20 to 100+. Do it right and forget about it.
          • Agree Agree x 1
          • missing linc
            1,922
            2868
            Feb 17, 2019
            Local Time:
            12:23 AM
            I ran an open element air cleaner year round, only had a problem once. Froze up on a really cold night on the highway
          • 66fs
            5,014
            1663
            Sep 9, 2009
            Local Time:
            2:23 AM
            Wow. I ran an original 68 unsilenced air cleaner without problems.
          • 66fs
            5,014
            1663
            Sep 9, 2009
            Local Time:
            2:23 AM
            Look for these on 73 up TQ manifolds. Relatively cheap, works great.
