340
1970mopar340
Member
elmore, ohio
I was hoping someone could give me some specific info on this engine, based on the numbers.
Thank you!
Does it belong in the car that's in YOUR garage?
This is a great gesture, I hope you find it's proper home!
Maybe place a post in the lost & found section of the website, you will probably get a better response........
Done.
That engine was built in Windsor...
Not that there's anything wrong with that, just stating a fact....
I only list items I have here, and all 9,000 plus of those fit inside file folders.
No one has sent in an engine......
Places to list engines and transmissions are, here on FABO in this section, on Moparts at Engine and Trans Lost & Found & one Facebook at MOPAR Broadcast Sheet,Engine and Transmission Reunion Group
And, random tip.......
Type the VIN or partial VIN out so if anyone looking can find your post with a search engine via the web.
