360 engine how far should oil pressure drop at idle?
Small Block Mopar Engine
  1. coalman
    coalman Well-Known Member
    1,042
    239
    Aug 6, 2015
    Texas
    Local Time:
    4:06 PM
    Engine at normal temperature At 750 rpm, what should oil pressure read at the minimum? Thanks
  2. fishmens67
    fishmens67 Well-Known Member
    8,413
    6082
    Nov 10, 2012
    idaho
    Local Time:
    4:06 PM
    10 psi minimum, but most have a least 25 to as much as 60 stock.
    My 73 W200 360 stock has 45 hot idle.
    • Agree Agree x 1
    • jay27
      jay27 Well-Known Member
      47
      21
      Dec 31, 2011
      Saskatchewan
      Local Time:
      3:06 PM
      Is it and old engine or rebuilt?
      What oil are you running?
      HV oil pump or a stocker?
      There are many variables , what is your hot oil pressure at idle?
      • Agree Agree x 1
      • 67Dart273
        67Dart273 FABO Gold Member FABO Gold Member
        45,108
        12717
        Oct 14, 2010
        Idaho
        Local Time:
        2:06 PM
        AND WHAT are you using for a gauge?
      • coalman
        1,042
        239
        Aug 6, 2015
        Texas
        Local Time:
        4:06 PM
        10w30 oil, 20 psi hot idle 650 rpm in drive stopped at traffic light. 60 psi driving, high performance engine was built about 7 seven years ago, in the car when I purchased it five years ago, not many miles on it. Auto Gauge direct reading gauge. Thanks to all
      • 318willrun
        318willrun Utube channel 318willrun
        15,522
        16654
        Sep 13, 2013
        I'm here
        Local Time:
        4:06 PM
        that is normal, no worries
        • Agree Agree x 3
        • coalman
          1,042
          239
          Aug 6, 2015
          Texas
          Local Time:
          4:06 PM
          Thanks!
        • MOPAROFFICIAL
          MOPAROFFICIAL FABO Gold Member FABO Gold Member
          6,484
          5443
          Jun 1, 2016
          Beach
          Local Time:
          2:06 PM
          650 is low idle, that's half of why its 20.
          750 would make it closer to 30, change to 30 or 20/50 and it would be mid high 30s.
          Reasons for variances.. bearing clearance/applies to failure or or general running clearance, engine oil temp, leakage, OIL WEIGHT.
          30 is what I recommend for nice weather.
          Extreme ends hot/ cold, 20/50
        • coalman
          1,042
          239
          Aug 6, 2015
          Texas
          Local Time:
          4:06 PM
          Thanks, I was thinking about both oils..
          • Like Like x 1
          • coalman
            1,042
            239
            Aug 6, 2015
            Texas
            Local Time:
            4:06 PM
            Tried the 20W50 oil.
          • MOPAROFFICIAL
            6,484
            5443
            Jun 1, 2016
            Beach
            Local Time:
            2:06 PM
            So what did you see?
            About 10 psi increase in hot idle or ?
          • coalman
            1,042
            239
            Aug 6, 2015
            Texas
            Local Time:
            4:06 PM
            I am going to drive it again, I think the idle psi was higher than that, going down the road it just about equal to the 10W30. Thanks
            • Like Like x 1
            • MOPAROFFICIAL
              6,484
              5443
              Jun 1, 2016
              Beach
              Local Time:
              2:06 PM
              Makes one feel a lot better. Glad to help.
              • Like Like x 1
              • coalman
                1,042
                239
                Aug 6, 2015
                Texas
                Local Time:
                4:06 PM
                Took it out, 30 to 34 psi at idle. Thanks
                • Like Like x 1
                • RustyRatRod
                  RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
                  64,725
                  37693
                  Jun 7, 2010
                  Georgia
                  Local Time:
                  5:06 PM
                  20 PSI at 650 hot with 10w30. I'd say you're good to go.
                  • Agree Agree x 2
                  • furrystump
                    furrystump Well-Known Member
                    1,091
                    701
                    Nov 13, 2004
                    Local Time:
                    9:06 PM
                    I’m about 25 hot idle, about 900-1000 rpm idle. I do a bunch of idling through the pits so I have a higher idle for more splash oiling for the cam, 20w50 Brad Penn grade 1, and shift at 6700 rpm. Have had no issues.
                  • Nat
                    Nat Well-Known Member
                    411
                    219
                    Jun 11, 2019
                    Netherland
                    Local Time:
                    9:06 PM
                    I idle at 850-900 and about 40 psi with 10-30 valvoline VR1 synthetic , i would not worry with 20 at 650 as long as it goes upwith the RPMS
                  • DARTLARRY
                    DARTLARRY Well-Known Member
                    477
                    130
                    Mar 19, 2007
                    FORT WAYNE IN
                    Local Time:
                    5:06 PM
                    20 psi. at 700pm idle 15W40.
                  • coalman
                    1,042
                    239
                    Aug 6, 2015
                    Texas
                    Local Time:
                    4:06 PM
                    I have 20W50 in it now, will see how that goes. Thanks for all the input.
                    • Like Like x 1
