360 LA 6psi timing map single turbo
Plato2k5
Anyone have a timing map for an LA with a single turbo runing 6psi on 93 pump? I have meth injection to keep the intake charge down and to add some fuel.
Have a good timing map rite now, just wondering if anyone has one I can compare with and see if I'm way under advance.
I don’t have an answer for you, but instead a question...
What are you using for adjustable ignition with an actual map?
Thanks, Eric
