[FOR SALE] 360 v8 motor
Sorry I didn't answer you sooner, I have clean block, fresh turned crank .010 rs, ms. one pair of 915 J heads, one pair 360 heads, bent valve, head bolts, rear sump oil pan with pick-up tube, 340 intake #3462848 4bbl, square bore, cast factory.NO rods or pistons, harmonic balancer, pushrods or rocker assemblies. Your choice of factory electronic, or points dist.PM me if you are interested.
