JWRICH
I have 2 standard-bore 360LA engine blocks with crankshafts available. Both are in excellent condition. I previously cleaned the cylinder bores on each for visual inspection / measurement, and then applied a heavy coating of lithium grease on all surface to prevent corrosion while in storage. Plan was to build one of these and keep the other as a spare, but I have decided to go a different route with my project. Each will come the crankshaft that was removed from the engine.
Box of parts includes original pistons, rods, distributor, and misc hardware, etc. This will go with the first engine sold if buyer wants it.
Marshalltown, IA 50158
No shipping. I can help with loading if needed.
$300 each
$550 for the pair
$300 each
$550 for the pair
