360X heads from RHS
CircleK21
Member
Just wondering if anybody has any feedback yet on the 360x heads
from RHS. Wondering how well they would perform on a 340 and what kind of flow #'s they put out. Tried asking RHS for a flow chart and they haven't got
any flow info as of yet. Any feedback/info would be great.
Thanks, Kevin
someone over at moparts.com is suppose to have a set coming. He said he will flow them OOTB, then do some port work on them.
look for member name... OU812.... His name is Brian.
They have Magnum chambers and ports so I would expect them to flow around the same as the EQ Magnums.
Nevermind (EQ = Engine Quest)
Well I'm looking for the best flowing pair of cast iron heads. If anyone has any insight as to which heads perform better, I'd love to hear it. I've heard that X heads are the best or that J heads flow the best, but still unsure.
standard magnum heads out flow both x and J heads...x and j heads have terrible exhaust...
if you can not exhale...you can not inhale...
The Engine Quest Magnums are probably your best bet for iron heads unless W2s ae legal in your class.
If you can port them (and find a pair) the R/T heads are great also.
