37 rattle
New Member
I have a 1973 Dodge Dart, I pull a after market wiring harness out of it because the way it was installed was all bad. I reinstalled a factory wording harness got everything working, started the engine and put it in gear and it kills the motor so I checked the wiring harness to the neutral safety switch and its not hooked up tore the steering column sort and nothing their shouting the motor off any idea what would cause this problem? :?
