383 engine mount
Big Block A body Tech
  1. Shmaako
    Shmaako Well-Known Member
    98
    17
    Aug 29, 2016
    Winnipeg, Manitoba, Canada
    Local Time:
    6:31 AM
    20200427_172848.jpg 20200427_201933.jpg I need help with how to install the mounts on my 383. The drivers side looks fairly straight forward but the passenger side mount rubber is offset horizontally and looks off. The motor is suspended using a lift in pic so it it will swing into alignment. I'm just talking about how the pad sits on the mount.
    Can anyone take a pic of a similar mount o
  2. HemiSSDart
    HemiSSDart Dartus Interuptus
    1,347
    908
    Feb 20, 2013
    Illinoisy
    Local Time:
    7:31 AM
    That is a small block rubber biscuit, not a big block. Here is a picture of what you need...
    • Agree Agree x 2
    • Like Like x 1
    • Shmaako
      98
      17
      Aug 29, 2016
      Local Time:
      6:31 AM
      That makes sense. Unfortunately, This motor came with this K member and mounts and I don't think it is a real BB K member. Im wondering if I get proper BB mounts they might not fit on this frankenstein K member.
      yeesh...perhaps this install will be postponed even more....(sigh)
    • Shmaako
      98
      17
      Aug 29, 2016
      Local Time:
      6:31 AM
      What is the problem with using these small block biscuits?
    • HemiSSDart
      1,347
      908
      Feb 20, 2013
      Illinoisy
      Local Time:
      7:31 AM
      Show me a pic of the drivers side mount.
    • Shmaako
      98
      17
      Aug 29, 2016
      Local Time:
      6:31 AM
    • HemiSSDart
      1,347
      908
      Feb 20, 2013
      Illinoisy
      Local Time:
      7:31 AM
      Well that is definitely not a factory big block A-Body k-frame. Looks like a small block k-frame, are you using Schumacher mounts?
      • Like Like x 1
      • Shmaako
        98
        17
        Aug 29, 2016
        Local Time:
        6:31 AM
        Not using schumacher mounts. Heres a pic of k member
      • Shmaako
        98
        17
        Aug 29, 2016
        Local Time:
        6:31 AM
        So after a little more research I believe they are Schumacher Creative Services 67-72 A-body SB to B/RB conversion motor mounts and brackets, biscuit style.
        '67-72 A-Body Products
      • gm1236
        gm1236 Well-Known Member
        136
        52
        Aug 3, 2013
        Massachusetts
        Local Time:
        6:31 AM
        Did you try to turn the rubber pad 90 degrees. All the one I’ve ever seen the long side runs top to bottom, short side is front to back. Like the driver side mount in the other photo.
        • Like Like x 1
        • RustyRatRod
          RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
          60,773
          32424
          Jun 7, 2010
          Georgia
          Local Time:
          7:31 AM
          @Jim Lusk is super good at this stuff. Maybe he'll chime in.
          • Like Like x 1
          • Shmaako
            98
            17
            Aug 29, 2016
            Local Time:
            6:31 AM
            You are correct. Thanks!
            It took me a bit to figure that out lol.
            And now I managed to rip the mount biscuit apart during the install...yeesh. Oh well, I heard Mancini sell them.
          • davescuda
            davescuda FABO Gold Member FABO Gold Member
            9,858
            1457
            Apr 30, 2007
            Cheshire, CT
            Local Time:
            6:31 AM
            I think this is what you have to do on the driver side from what I have seen. I am sure someone that did this will jump in
            take out that spacer
            you have cut the K frame, red square
            • Like Like x 1
            • jimharvard
              jimharvard JimHarvard FABO Gold Member
              706
              249
              Jan 7, 2007
              Pittsburgh, Pennsylvania
              Local Time:
              7:31 AM
              hey Shmaako...
              i'm building a 69 M-Code Cuda right now and went through the issue of the big block k-member problem.
              i had a small block 340 k-member, however, the 383-440 k-member is a little different. i found a big block k-member here on FABO. there used to be motor mounts available to put a big block engine on a small block k-member but right now, the companies that were making them are either out of business or not producing anything. the big block motor mounts are available but they only fit on the big block k-member. the below picture pictures show the difference between the small block k-member and the big block one. the small block motor mounts are right across from each other - even. the big block motor mounts are "off-set" from one another.
              • Thanks! Thanks! x 1
              • Jim Lusk
                Jim Lusk Well-Known Member
                4,365
                729
                Mar 8, 2006
                Fresno, CA
                Local Time:
                4:31 AM
                Yup, looks like small block k-member with conversion mounts. I believe that some of the conversion mounts mounts the insulator like that. I've always built my old Direct Connection k-member so I've never had to deal with conversion mounts.
              • carguy47
                carguy47 Well-Known Member
                474
                37
                Feb 5, 2015
                Phoenix, Arizona
                Local Time:
                5:31 AM
                I am having the same issues with a 440 in a '68 dart. The other issue I have NOT been able to solve is the exhaust manifolds. I purchased several versions from various years and have no luck on the driver's side. I am going to weld up a driver's side motor bracket.
                ANY ideas on the driver's side exhaust manifold?
              • carguy47
                474
                37
                Feb 5, 2015
                Phoenix, Arizona
                Local Time:
                5:31 AM
                Got the passenger side in with a 1/4" to spare
              • Jim Lusk
                4,365
                729
                Mar 8, 2006
                Fresno, CA
                Local Time:
                4:31 AM
                '68-73 B-body HP manifold with the outer sleeve on the steering column cut up to the firewall. The clearance is MINIMUM to the shaft, but it will work. You can also shift the column and box a little to the left for a little more clearance.
              • Dcuda69
                Dcuda69 Well-Known Member
                196
                12
                Jul 14, 2008
                Local Time:
                6:31 AM
                With the BB K frame you'll also need the BB mount bracket to match. It wraps around the front of the block and bolts in 2 holes above the oil pump(you'll also need a block with those holes) That's the setup I run in my 69 B'cuda with a 400 based 470"
              • 1969383S
                1969383S FABO Gold Member FABO Gold Member
                5,563
                2598
                Jan 8, 2012
                Cumming, GA.
                Local Time:
                7:31 AM
                Wow! Lots of struggle!
                It is nice to be original and simple! Never dealt with these issues.
