johnparts
Slammed 1
I have a 4.7 magnum engine SOHC out of a 2002 Dodge Durango with EVERYTHING harness, accesories, intake to pan, even the dash cluster and ignition wiring along with a 518OD trans and transfer case. Also I have a 1974 A-833 OD trans and bellhousing that has been modified to work with this engine should you choose to go manual. I'm asking for $1000 or best for the engine plus 1 transmission. Engine has 102k miles on it but runs strong no noisesno smoke. Valve cover gaskets seep a bit of oil but nothing major. Came out of a rear ended truck.
