SWED67barracuda
Hi , Has anybody on this forum ever used Milodon 4Bolt maincaps #MIL-11300.I`m buildin a 0,040 over 340 with W2 heads and thinks these look OK.But experienses are always fine to know about . Best regards Ubbe.
They say it pulls from the sidewalls of the block and not the flimsey main web area , but do the outer bolts really reach that far out. I have seen some kind of girdle that bolts on the main caps, could that be something to use?I used em on mine. Have not had any problems, but looking at it there is not much meat on the block where the extra hole is tapped. Would not do it again.
Ok Thanks for input . Saves a bunch of money , I`ll buy ARP studs instead.Would not use girdle. Honestly many w2 headed 2bolt main small blocks were raced in 70's and 80's...biggest problem was keeping oil to the rod and main bearings.
Thanks for picture , , I agree , they look different in a better way.I have 2 blocks here, 1 has Pro Gram caps and another has what I assumed were Milidon caps. I don't think I would do it, unless nessasary. I think I like the Pro Grams better
Thanks , very helpful picture , So the outer bolts are somewhat offset to the centerline . I think i must do some measurements on my block , just because , even if I`ll go along with what QKFSH67 says about the matter.View attachment 1715094222
This block was fitted with program caps by ray Barton years ago.
Maybe no help here, but I had the splayed bolt caps installed in a really hot 406 sbc, the main caps still walked around , but like I said it was a high h.p. engine !Thanks , very helpful picture , So the outer bolts are somewhat offset to the centerline . I think i must do some measurements on my block , just because , even if I`ll go along with what QKFSH67 says about the matter.
Hi there Rocket , That looks real nice .I Think you got my e-mail adress , I bought the heads from you. Please forward info. Best regards Ubbe.I used some beefier iron aftermarket 4 bolt MP caps and cut the outer tabs off and used good studs. Seems to work well. Program and a couple of other aftermarket companies offered 2 bolt caps. I may still have correspondence with one of them I can forward if you are interested. Just PM me an email address.
View attachment 1715094486 View attachment 1715094487
