4 - Mopar 1 & 2 barrel carbs as follows:
All linkages on all carbs move freely. All are for automatic transmissions. All non lean burn. All are plus shipping cost from 18403.
1-Carter BBD 6150S (3501/08) 2 Barrel. Off a 72 Dodge 318. W/choke thermostat. No choke pull off. Might needs a rebuild. $60. Neg.
1-Holley 1920 (12R-3106) 1 Barrel. Off a mid 60's 225 Dodge. No choke thermostat. Choke pull off works. Absolutely needs a rebuild. $50. Neg.
1-Holley 2245 (R6731A) 2 Barrel. Off a 74 360 Plymouth (Pretty sure). No choke thermostat. Choke pull off doesn't hold. Definitely needs a rebuild. $75. Neg.
1-Holley 2245 (R7644A) 2 Barrel. Off a 360. Model??? W/ electric assist choke thermostat. Choke pull off doesn't hold. Might need a rebuild. $75. Neg.
