4 piston disc brakes
elvaliant66
EL MONTE ,CA
Curious on what you guys think is a reasonable price for a set up of 4 piston small bolt pattern disc brakes. I seen the set up for sale on eBay going for $275 . Has all the hard parts even upper control arms
Yeah, but keep in mind that used calipers are almost always stuck. Usually just turn them in for cores and get new ones for roughly $100/each. But anyway, I paid closer to $400 recently for the same package, so go for it.
About right if it includes the spindles and dust plates. Primo price if the booster, MC, prop valve and tubing is included. The UCA is the same as 9 or 10" drums, but the lower ball joint differs. You can get rebuilt calipers on rockauto for ~120 ea, depending on if you have cores. A guy here sells a nicely rebuilt kit for $900, I recall w/o booster/MC. Insure no critical parts are missing. Some have gone bonkers trying to source the special hose brackets that attach to the calipers and dust plates alone can command $100/pr.
